Lets end some of the alcohol MYTHS
#2530033
08/01/18 03:46 PM
08/01/18 03:46 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We've all heard it time and time again on how hard alcohol is to run and keep the water moisture out of it. I changed my oil "last year" at the beginner of September to get ready for all the long weekend races around Halloween. Last week 7-24-18 I changed it for the first time this year. My racing season ended the last week of October and started again the second week of April. I prefer Brad Penn as I have stuck with it through 3 different name changes at least over the last 44 years and have had zero issues with it. The steps are easy. 1. Get the jetting right. I have both O2's and EGT readings that I use. 2. Get heat in the engine (180 plus) 30 minutes before race time. 3. lean-out valve to build heat. I use a 1/2 inch ball valve 4. get it up to at least 165 degrees before starting your burn-out 5. After a pass shut off you fan, water pump, and open the lean out valve driving back to the pits after a pass. 6. Never ever just for the heck of it start your car during the week and rev it up to impress your buddies. Pretty simple procedure that works. Here are some pictures from my oil change last week. I didn't even have to wipe out my valve covers or head drain-backs like I see guys doing that run pump gas or race gas. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr
Re: Lets end some of the alcohol MYTHS
[Re: pittsburghracer]
#2530056
08/01/18 04:30 PM
08/01/18 04:30 PM
Posts: 4,206 New York
polyspheric
New York
You forgot Rule 0.: "be an adult who listens to good advice".
Boffin Emeritus
[Re: polyspheric]
#2530063
08/01/18 04:36 PM
08/01/18 04:36 PM
BradH
Alcohol Myth #1: Margaritas on the rocks are better than frozen. Seriously, a Tequila Slushee rocks! Alcohol Myth #2: Margaritas without salt on the rim of the glass are totally acceptable. Whaaaaaaaaaaaat?! NO SALT??? ---------------------------- We now return you to your regularly scheduled Moparts post.
#2530078
08/01/18 04:54 PM
08/01/18 04:54 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I'm with Brad, although I prefer mine on the rocks with GOOD tequila I can rock a slushy when the time arises
#2530111
08/01/18 05:54 PM
08/01/18 05:54 PM
polyspheric
New York
IIRC chamois used as a filter will remove water on each pass? Enough to make it worthwhile - IDK.
Boffin Emeritus
[Re: CMcAllister]
#2530117
08/01/18 06:23 PM
08/01/18 06:23 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
And some wonder why Mopar guys are stuck in the purple shaft days. Lol 😂
[Re: polyspheric]
#2530181
08/01/18 08:41 PM
08/01/18 08:41 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
IIRC chamois used as a filter will remove water on each pass? Enough to make it worthwhile - IDK. Sham-WOW. 😁
[Re: Porter67]
#2530200
08/01/18 09:26 PM
08/01/18 09:26 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Your just a "special" guy, thats part of it. Not sure what you mean by that but I’m all ears. Let it out
