Anyone used MT ET Street R bias tires? #2529947
08/01/18 12:56 PM
08/01/18 12:56 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
My local track runs street car race several times a season and the track prep is bad. My car has MT 325 ET radials so everyone know how well that works. Normally the problem it's just getting off the line but two weeks ago it turned loose in second gear and I almost crossed the center line before I got it caught up.
Has anyone ran the MT Street R bias ply tire? Has anyone tried them tubless? If I run tubes will I have to run screws?
Thanks, Justin
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2529954
08/01/18 01:03 PM
08/01/18 01:03 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Hoosier QuickTime Pro.
Re: Anyone used MT ET Street R bias tires? [Re: fbs63] #2529961
08/01/18 01:13 PM
08/01/18 01:13 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep. Ran them on my 9 sec s/s spring Duster for years and they would hook on ice.
Great tire.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2529973
08/01/18 01:35 PM
08/01/18 01:35 PM
W. Kentucky
W. Kentucky
These were ran on the street/ Tubes and screws?
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2529977
08/01/18 01:41 PM
08/01/18 01:41 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep. I liked runnng tubes because the sidewall became stiffer. And i did use screws.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2529979
08/01/18 01:42 PM
08/01/18 01:42 PM
an8sec70cuda Offline
Like any other bias ply tire, if you run a tube in them, you need to be sure the tire doesn't slip on the rim. Either screws or beadlocks would be my suggestion.
Gluing them, like you do with radials, isn't guaranteed and isn't worth the chance of tearing the tube and losing air pressure going down the track.
Don't want screws or beadlocks? Then go tubeless and just deal w/ a lil leakage.
I have not run the new ET Street R tires, but I ran the old ET Street bias ply tires for many years. They'd lose a couple or 3 pounds of air overnight w/o tubes...no big deal.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Anyone used MT ET Street R bias tires? [Re: an8sec70cuda] #2529982
08/01/18 01:47 PM
08/01/18 01:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
You guys that have leaking tires going tubless aren’t prepping them right.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone used MT ET Street R bias tires? [Re: pittsburghracer] #2530002
08/01/18 02:21 PM
08/01/18 02:21 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
With radials i have went tubeless, but with bias tires i always ran tubes. Just stiffen up the tire a good bit. Nothing to do with leaking
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anyone used MT ET Street R bias tires? [Re: pittsburghracer] #2530012
08/01/18 02:44 PM
08/01/18 02:44 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Rubbing dawn dish soap on inside of tires works for me. Rarely have to add air.
Re: Anyone used MT ET Street R bias tires? [Re: mopar dave] #2530035
08/01/18 03:52 PM
08/01/18 03:52 PM
W. Kentucky
W. Kentucky
This is what I've done with slicks and had good results. The reason I was looking at the MT tires is that are supposed to have a stiffer sidewall.
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530038
08/01/18 04:01 PM
08/01/18 04:01 PM
PA.
"Little"John
"Little"John
PA.
I coat mine with a Dawn and water solution and let it dry. The next day I coat them again then I prep and clean the bead to remove the "mold compound" with paint thinner, scuff them with red scott pad, and clean them again. Then I glue them on with High Tach sealer. I lose less than 1 pound of air during 5 months of winter storage.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530070
08/01/18 04:42 PM
08/01/18 04:42 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Would this be the tire your asking about? I am going back to all radial and will be ordering a pair at months end. I am currently using a QTP.
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530079
08/01/18 04:55 PM
08/01/18 04:55 PM
W. Kentucky
W. Kentucky
These are the tires I was looking at Dave.
http://www.mickeythompsontires.com/drag-tires/et-street-r-bias
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530087
08/01/18 05:11 PM
08/01/18 05:11 PM
central il.
second 70 Offline
second 70  Offline
central il.
Justin I run them tubeless on my Cuda and havn't had any trouble.
bought them from Larry Hodge Racing tire. I asked him about it and he said tons of guys race them tubeless and the trick to spay the rim with hairspray when installing which actually glues them to the rim and no need to use dawn.
He sells a lot to racers and could help you with your choice. Give him a call 217 677 2358 office, cell 217 433 3060 his price was the lowest and he also sells Hoosier
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530104
08/01/18 05:44 PM
08/01/18 05:44 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I think people are confusing the “ running them without tubes “ and they leak.
Everybody seems to know how to make the tires hold air without tubes.......
My point wasnt about holding air, my point was i run tubes on QTP’s only because it stiffens the sidewall. I have run them with and without tubes, prefer tubes, stiffer sidewall
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anyone used MT ET Street R bias tires? [Re: B3422W5] #2530114
08/01/18 06:08 PM
08/01/18 06:08 PM
central il.
second 70 Offline
second 70  Offline
central il.
I understand why you run tubes in QTP. The side walls are stiffer on the MTs and even with that I agree on a heavy car like mine that tubes would help the sidewalls.
Re: Anyone used MT ET Street R bias tires? [Re: second 70] #2530141
08/01/18 07:05 PM
08/01/18 07:05 PM
W. Kentucky
W. Kentucky
Thanks, when I make up my mind I'll give Larry a call.
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530164
08/01/18 07:50 PM
08/01/18 07:50 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thanks for the pic. Tread pattern is same but the rest of the tires looks a little different. Didnt know those existed.
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530295
08/02/18 12:59 AM
08/02/18 12:59 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I think it was BIGCUBE that posted several years ago and I'm paraphrasing: SFI wheels don't need bead locks or screws with tubes. Anyway, I tried it. Mid 10's, 3700lbs, MT ET Bias Streets, Tubes, no screws. Many many many passes, no issues. smile
Re: Anyone used MT ET Street R bias tires? [Re: justinp61] #2530328
08/02/18 02:37 AM
08/02/18 02:37 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I am running a set tubeless on my heap.
I went to the track for the first time with them last week.
Although I am having some traction issues with them, I have a 4 speed with no line loc, so just a 2nd gear rolling burnout is not heating them up enough, plus the track prep was nill.
I lose about 5 lbs of air out of one every couple weeks,the other loses none.
