Felpro head gasket for a 408 stroker #2529898
08/01/18 11:22 AM
08/01/18 11:22 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I have a mild 408 stroker with iron heads. I'm looking for the part number for the Felpro permatork head gasket.
Is it the FEL8553PT?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Felpro head gasket for a 408 stroker [Re: cdstl] #2529907
08/01/18 11:46 AM
08/01/18 11:46 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
1008
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Felpro head gasket for a 408 stroker [Re: cdstl] #2529913
08/01/18 11:59 AM
08/01/18 11:59 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Depends on exactly how “mild” it is.
Re: Felpro head gasket for a 408 stroker [Re: cdstl] #2529917
08/01/18 12:02 PM
08/01/18 12:02 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
yes, thats the stock replacement head gasket, as mentioned, race gasket is 1008. Depends on your " needs".
RIP Monte Smith
Re: Felpro head gasket for a 408 stroker [Re: cdstl] #2529956
08/01/18 01:05 PM
08/01/18 01:05 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Sounds like the 1008 would be the way to go.
Re: Felpro head gasket for a 408 stroker [Re: cdstl] #2529965
08/01/18 01:21 PM
08/01/18 01:21 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Yep, I have the iron RHS heads on mine, maybe 450hp, FelPro 1008.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
