Felpro head gasket for a 408 stroker
#2529898
08/01/18 11:22 AM
08/01/18 11:22 AM
Posts: 1,487 STL
cdstl
STL
I have a mild 408 stroker with iron heads. I'm looking for the part number for the Felpro permatork head gasket.
Is it the FEL8553PT?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Felpro head gasket for a 408 stroker
[Re: cdstl]
#2529913
08/01/18 11:59 AM
08/01/18 11:59 AM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Depends on exactly how “mild” it is.
[Re: cdstl]
#2529917
08/01/18 12:02 PM
08/01/18 12:02 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
yes, thats the stock replacement head gasket, as mentioned, race gasket is 1008. Depends on your " needs".
RIP Monte Smith
[Re: cdstl]
#2529956
08/01/18 01:05 PM
08/01/18 01:05 PM
Posts: 1,487 STL
cdstl
STL
Sounds like the 1008 would be the way to go.
[Re: cdstl]
#2529965
08/01/18 01:21 PM
08/01/18 01:21 PM
Posts: 860 lancaster,california
johnnycuda
Yep, I have the iron RHS heads on mine, maybe 450hp, FelPro 1008.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
