Are '69 bucket seats the same for A/B bodies? #252936
03/13/09 06:09 PM
03/13/09 06:09 PM
NE Oklahoma
O
OkieSwinger69 Offline OP
O
NE Oklahoma
First, are bucket seats interchangable for 69 A and B bodies? Also, are 68 A body buckets the same as 69 A buckets (except the covers of course)?
Re: Are '69 bucket seats the same for A/B bodies? [Re: OkieSwinger69] #252937
03/13/09 08:59 PM
03/13/09 08:59 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I know the tracks are different. I have a pair of 69 A buckets and they won't bolt into my 70 B body. The track spacing is narrower. Don't know if the bucket itself is the same or not?
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Are '69 bucket seats the same for A/B bodies? [Re: phantomx] #252938
03/14/09 12:08 AM
03/14/09 12:08 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
68 and 69 A and B Bodys use the same seat frames.
Risers are specific to A and B and do not interchange. So yeah a 69 Charger bucket will fit a 68 Dart as long as you use A Body risers and vice versa.Seat back release knobs are different between years but interchange.Seat backs,hinge covers,headrests and hardware all interchange .
"Long Live Mopars"
Re: Are '69 bucket seats the same for A/B bodies? [Re: Furyman] #252939
03/14/09 09:56 AM
03/14/09 09:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm pretty sure the seat foam itself is also different between the seats , not that the repop foam that is available fits the intended application correctly either .
Re: Are '69 bucket seats the same for A/B bodies? [Re: JohnRR] #252940
03/14/09 12:34 PM
03/14/09 12:34 PM
NE Oklahoma
O
O
NE Oklahoma
So if one were to buy some 69 B body buckets intended for use in a 69 Dart, it sounds like the only thing usable is the seat frame, head rests and accessories. The right tracks and risers would have to be located and the foam changed out to accomodate 69 covers. Is this right?
Re: Are '69 bucket seats the same for A/B bodies? [Re: OkieSwinger69] #252941
03/14/09 01:33 PM
03/14/09 01:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm not 100% on the foam , but yes the seat tracks are different , Risers, not sure what you mean by that ?
Re: Are '69 bucket seats the same for A/B bodies? [Re: JohnRR] #252942
03/14/09 07:29 PM
03/14/09 07:29 PM
NE Oklahoma
O
O
NE Oklahoma
I'm not 100% sure what risers are either. I assume they attach to the tracks and to the floor pan.
Re: Are '69 bucket seats the same for A/B bodies? [Re: OkieSwinger69] #252943
03/14/09 08:32 PM
03/14/09 08:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The tracks in an A body bolt DIRECTLY to the floor pan , the only thing you would need if converting a non bucket seat car to buckets is the extra support plates that are welded to re enforce the floor pan .
Re: Are '69 bucket seats the same for A/B bodies? [Re: OkieSwinger69] #252944
03/14/09 08:44 PM
03/14/09 08:44 PM
ne
broncobra Offline
broncobra  Offline
ne
I bought some b body seats for my b body and they have tracks and also on each side a stamped metal mount that goes from front to back about 3 inches tall on one end to about 4 inches tall on the other end. I think this is the riser he is refering to. Are all 66 to 70 b body bucket seats the same frame? They sure all look the same in the Legedary catalog, but Legendary can't tell me for sure if covers from a 68 b body will fit a 67 b body seat. I hate the pattern in mine and want to change it to a better style.
Re: Are '69 bucket seats the same for A/B bodies? [Re: broncobra] #252945
03/14/09 09:02 PM
03/14/09 09:02 PM
NE Oklahoma
O
O
NE Oklahoma
Yeah, that's my take on it. The riser being part of the track assembly and on an A body the inside track riser being taller than the outside.
Thanks for the help.
