Rebuilt power steering box vendor #2528541
07/29/18 09:23 AM
07/29/18 09:23 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Looking to purchase a power steering box for a '70 B-Body, stock is fine for my purposes. Where to go for reliable purchase?
Board search came up somewhat empty.
Everyone have a great Sunday
Gary
"I think its got a hemi"
Re: Rebuilt power steering box vendor [Re: gdonovan] #2528545
07/29/18 10:43 AM
07/29/18 10:43 AM
louisa, ky
seaworthy10 Offline
seaworthy10  Offline
louisa, ky
steer&gear columbus oh have done several for me works great for me extra firm feel steers like a modern car. jms
Re: Rebuilt power steering box vendor [Re: gdonovan] #2528579
07/29/18 12:19 PM
07/29/18 12:19 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I’ve read quite a few posts that say the remans from Lares, on Rock Auto are the way to go for just a general stock replacement.
68 Charger R/T 440 auto
Re: Rebuilt power steering box vendor [Re: gdonovan] #2528604
07/29/18 01:38 PM
07/29/18 01:38 PM
Andrewh Offline
Andrewh  Offline
So I did this about a year ago, maybe 2.
Everyone here recommended firm feel or steer and gear, with a couple of exceptions.
As mentioned above Lares remans were also recommended.
I found advanced auto had online discounts and ship to store for free.
I decided to order a 74 and up box so I could use the cheaper pitman arm as well.
while it still has some play in it, the old one was much worse.
But the alignment guy still never quite got the steering wheel straight.
Calling lares they said I had to have the car running, and even with that, the slop has me steering slight the off center. not holding like it drifts, just that the alignment shop couldn't get any closer.
before I would say something like 70 to 80 degrees before the steering "Caught" and the car would turn.
now it is more like 10-25 degrees.
I would say a hand in either direction before it catches.
A few detractors of firm feel and steer and gear pointed out I might get the same thing from them, AND be on the hook for shipping if I wanted it fixed.
the price at the time was like 150 for the lares through advanced auto.
so it was a no brainer cost wise.
I see now they don't offer that box anymore.
rock auto does and it is around 250 with 100 dollar core.
FF is close to 400 with 250 core charge.
steer and gear is 320 plus 195 core
and you are paying for shipping back for both, not sure about shipping to you.
Re: Rebuilt power steering box vendor [Re: gdonovan] #2528638
07/29/18 03:23 PM
07/29/18 03:23 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I bought a Level 2 box from Firm Feel a while back, no great change in feel but I wanted to run the fast ratio pitman and they can limit the stops for you. If I had to do it again I would just go Rockauto.
Andrewh - sounds like your box might be "off neutral," might want to find a better alignment tech or spend an afternoon with the FSM.
Re: Rebuilt power steering box vendor [Re: wesgtx440] #2528644
07/29/18 03:39 PM
07/29/18 03:39 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Really??
I have only heard that the parts store rebuilds are nothing more than cleaned and REgasket jobs...NO hard parts are replaced so if that chuck was loose and sloppy before, it is just as bad after.
It mostly comes down to WHERE you are in the USA. Closer to the West Coast? FIRM FEEL in Washington state. Since you are near the EAST coast, Steer and Gear is much closer. Both have great service but Firm Feel develops and sells more products including suspension rebuild parts, torsion bars, sway bars, shocks, brake pads, etc.
Re: Rebuilt power steering box vendor [Re: Kern Dog] #2528727
07/29/18 06:59 PM
07/29/18 06:59 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
If that is the case, I'll consider resealing a stock box I have here from a '74 Dart. If they replaced bushings as well then I'd consider a "rebuild" but I was wondering how in depth the rebuilds were.
Re: Rebuilt power steering box vendor [Re: gdonovan] #2530011
08/01/18 02:36 PM
08/01/18 02:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I got a cardone rebuild for a Durango once , it wasn't better than the box it replaced , a little better than the one I got for it from the local junkyard.
If the box doesn't get new gears during the rebuild it won't be much better than it was when it was returned.
Re: Rebuilt power steering box vendor [Re: gdonovan] #2530243
08/01/18 10:54 PM
08/01/18 10:54 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I put a FF Stage 3 in my 70 sport satellite . . . firm at speed and its a tighter than regular mopar power steering when at slow speed . . . I had a stage 2 in my 74 Duster360, and it did not feel any different than regular mopar power steering.
Re: Rebuilt power steering box vendor [Re: gdonovan] #2530310
08/02/18 01:34 AM
08/02/18 01:34 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I have heard that before. There must be a noticeable difference between the Stage 2 and the Stage 3. Mine feels great....Stage 3 and Fast Ratio arms.
Re: Rebuilt power steering box vendor [Re: gdonovan] #2530462
08/02/18 01:35 PM
08/02/18 01:35 PM
None
71rm23 Offline
71rm23  Offline
None
Stage 3 has a different "worm" gear in it is what I was told
Re: Rebuilt power steering box vendor [Re: gdonovan] #2530809
08/03/18 02:27 AM
08/03/18 02:27 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I thought the worm gear changed the ratio. ALL of Firm Feels power gear boxes are the same 15.7 to 1 ratio.
Re: Rebuilt power steering box vendor [Re: Kern Dog] #2530817
08/03/18 03:23 AM
08/03/18 03:23 AM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
How do you like the fast ratio? I'm liking the 14:1 of the borgeson.
Re: Rebuilt power steering box vendor [Re: gdonovan] #2531120
08/03/18 07:10 PM
08/03/18 07:10 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The stock chuck with the Fast ratio arms alters the ratio to approx. 12 to 1. It feels heavier to steer than any other Mopar that I have ever owned. I like it. It still has that free play from center but then again, I have never rebuilt the coupler.
Re: Rebuilt power steering box vendor [Re: Kern Dog] #2532503
08/06/18 09:09 PM
08/06/18 09:09 PM
dogdays Offline
dogdays  Offline
Look up Lares online https://www.larescorp.com/. They are NOT Cardone. They are a better company freezing their butts off in Minnesota, not sunbathing in Tijuana (or Shanghai).
The "I have heard" termite strikes again!
R.
Re: Rebuilt power steering box vendor [Re: gdonovan] #2532629
08/07/18 02:13 AM
08/07/18 02:13 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Check this vendor site for some steering goodies: http://bergmanautocraft.com/
Re: Rebuilt power steering box vendor [Re: Montclaire] #2533095
08/07/18 11:49 PM
08/07/18 11:49 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Lares rebuilding service is available at rock auto and using there shipping is very reasonable to
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Rebuilt power steering box vendor [Re: gdonovan] #2573762
11/04/18 06:17 AM
11/04/18 06:17 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
FREE shipping at Bergman Auto Craft on the kit or just the box.
