Re: Mountain Motor Pro Stock cars
[Re: theraif]
#2528310
07/28/18 03:38 PM
07/28/18 03:38 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m sure most of the current nhra pro stock teams loved hearing that news.
[Re: fast68plymouth]
#2528321
07/28/18 04:06 PM
07/28/18 04:06 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
7 years to late to save the class. All the IHRA engines are probably sold off and the racers moved on
[Re: theraif]
#2528326
07/28/18 04:35 PM
07/28/18 04:35 PM
fast68plymouth
So. Burlington, Vt.
It’s probably an effort to try and attract some “lower funded” teams to compete. I’m sure a used IHRA mountain motor is cheaper than buying a new version 500ci EFI piece.
[Re: theraif]
#2528330
07/28/18 05:03 PM
07/28/18 05:03 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
If it was limited to bodys made before 1980 that would be something.
Have a great day Iowan
"obsolete is neat"
[Re: Dartari]
#2528345
07/28/18 05:40 PM
07/28/18 05:40 PM
Iowan
Lost in Time
How about mountain motor prostock using real body in white cars like the challenger ,camaro,mustang or any rwd car I like that!
"obsolete is neat"
[Re: theraif]
#2528348
07/28/18 05:47 PM
07/28/18 05:47 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Dozen-15 cars in PDRA usually. They put on a good show. And they're not all Camaros and a number of engine builders are involved. Looking at the 660 numbers they are pretty close to the 500" cars. Should be able to adjust some minimum weights a few pounds and be close. Glad to see it, should spark some interest in the class. I still like and appreciate the NA stuff. All about the motor.
[Re: theraif]
#2528381
07/28/18 07:25 PM
07/28/18 07:25 PM
Posts: 20,813 A collage of whims
topside
A collage of whims
PS needs manufacturer diversity, less overhead to compete, and arguably closer relation to Stock or SS, though that isn't a deal-breaker. Right now, seeing a bunch of the same cars, that look more like PM or FC than an actual car, loses the visual appeal. The expense loses anyone who isn't a millionaire or well-connected. I don't see the value of the EFI switch, except to the supporting vendors (follow the money?) or rules that favor one make (follow the money again?)... I'm OK with bringing in the Mountain Motor cars, but that could be difficult to manage unless there's at least a weight/size formula. I think NHRA needs to re-think what Stock, SS & PS cars ought to be, but that's gonna hurt a lot of guys. Obviously, one of the key problems is the demographic NHRA is trying to reach, and whether that has more value than tradition.
