Driveshaft loop with tti x-pipe #2526718
07/25/18 01:30 AM
07/25/18 01:30 AM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
My street strip 65 belvedere finally has some power and I wanted to put a loop on it before hitting the track again. Has anyone used one of those driveshaft loops that bolt to the transmission cross member? Not sure if the x-pipe Will work with this one or not. Mancini racing sells them.
I don't really have any fabrication facilities at my place and the bolt on unit seems easy.
Any help is greatly appreciated. Thanks guys.
63 Plymouth savoy
65 d100
66 dart race project
58 plymouth suburban
Re: Driveshaft loop with tti x-pipe [Re: hosehead] #2526743
07/25/18 03:37 AM
07/25/18 03:37 AM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
I've been contemplating a loop for my 64 and have the tti x-pipe as well. Car has buckets so seat bolts are right there or was thinking of something mounted to the x-pipe itself.
Re: Driveshaft loop with tti x-pipe [Re: hosehead] #2526766
07/25/18 09:41 AM
07/25/18 09:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My E-body has a 3" TTI x-pipe system and one of the U.S. Car Tool (?) bolt-on loops. The bolts that hold the loop to the main "frame" of the assembly caused a clearance issue, so I had that part of it welded to eliminate the bolts sticking up into the exhaust.
Re: Driveshaft loop with tti x-pipe [Re: hosehead] #2526820
07/25/18 11:58 AM
07/25/18 11:58 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I run the us car tool bolt in on my a body with the tti x pipe. I have my doubts about whether the loop as sold would control the shaft. I made a strap that goes from the loop to the seat
studs to give the whole thing more support. Happy with it now.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Driveshaft loop with tti x-pipe [Re: hosehead] #2526890
07/25/18 01:56 PM
07/25/18 01:56 PM
Locomotion Online content
Locomotion  Online Content
I have TTI headers & 3" X-pipe on my Dart with a conventional driveshaft loop. I had to dent the tubes near the X to clear. I'm sure it didn't hurt flow. I had a little back & forth adjustability available because the loop was already there and I was adding the X-pipe & exhaust. I think I had to do the same with my Aspen wagon, so it appears that a little denting may be necessary in most applications.
Re: Driveshaft loop with tti x-pipe [Re: hosehead] #2527094
07/25/18 09:11 PM
07/25/18 09:11 PM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
Thanks for the responses guys. I think I'll order one tomorrow.
63 Plymouth savoy
65 d100
Re: Driveshaft loop with tti x-pipe [Re: hosehead] #2531636
08/04/18 09:37 PM
08/04/18 09:37 PM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
I used the METCO loop on my E body and used TTI headers and 3" X pipe. I had no clerance issues using the METCO loop.
Still Broke
Re: Driveshaft loop with tti x-pipe [Re: hosehead] #2531776
08/05/18 02:21 AM
08/05/18 02:21 AM
Utah, USA
1964superstock Offline
Utah, USA
I am using a METCO driveshaft loop in my '64 Savoy, along with a TTI X-Pipe 3 inch exhaust system. I modified it, to be egg shaped with, 3/4 inch added to the loop above the driveshaft, and about 1 inch added to the loop below the driveshaft for clearance. Also added two gussets to the driveshaft loop to reinforce.
