Damper & MSD crank Trigger #2524979
07/21/18 01:43 PM
07/21/18 01:43 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Does anyone run a FLU-720311 Damper and a MSD crank Trigger? Are Spacers Required to attach the crank trigger to the Damper? I see the ATI Damper is a flat face mount.
Re: Damper & MSD crank Trigger [Re: RATTRAP] #2525125
07/21/18 11:03 PM
07/21/18 11:03 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It looks like the Flu-720311 is flat faced also. Normally no spacer should be used. Is there a reason you would want to space it out?
Re: Damper & MSD crank Trigger [Re: RATTRAP] #2525191
07/22/18 01:41 AM
07/22/18 01:41 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I ended up making a custom adapter for mine. Its from 2004 so I don't know if the damper design has changed any or not since then. It is part number 720311.
Re: Damper & MSD crank Trigger [Re: RATTRAP] #2525481
07/22/18 06:42 PM
07/22/18 06:42 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The face of my ATI is flat faced with a spacer to locate the belts. Are you using any drive belts?
I don't have a trigger yet,but ATI makes a different front/face plate with magnets built in.I don't know yet if that works well or just use the wheel work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Damper & MSD crank Trigger [Re: RATTRAP] #2526513
07/24/18 05:44 PM
07/24/18 05:44 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I Don’t remember the P/N of the Fluid Dampner I had on my 440. But I too had to have a spacer made to run the MSD crank trigger. I think the old ones were recessed so the crank pulley would line back up with the water pump pully
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Damper & MSD crank Trigger [Re: RATTRAP] #2526833
07/25/18 12:18 PM
07/25/18 12:18 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I ran into the same issue. I used this
http://www.manciniracing.com/bicrpusp.html
It made life a lot easier
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
