Re: Damper & MSD crank Trigger
[Re: RATTRAP]
#2525125
07/21/18 11:03 PM
07/21/18 11:03 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
It looks like the Flu-720311 is flat faced also. Normally no spacer should be used. Is there a reason you would want to space it out?
[Re: RATTRAP]
#2525191
07/22/18 01:41 AM
07/22/18 01:41 AM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
I ended up making a custom adapter for mine. Its from 2004 so I don't know if the damper design has changed any or not since then. It is part number 720311.
[Re: RATTRAP]
#2525481
07/22/18 06:42 PM
07/22/18 06:42 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
The face of my ATI is flat faced with a spacer to locate the belts. Are you using any drive belts? I don't have a trigger yet,but ATI makes a different front/face plate with magnets built in.I don't know yet if that works well or just use the wheel
[Re: RATTRAP]
#2526513
07/24/18 05:44 PM
07/24/18 05:44 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
I Don’t remember the P/N of the Fluid Dampner I had on my 440. But I too had to have a spacer made to run the MSD crank trigger. I think the old ones were recessed so the crank pulley would line back up with the water pump pully
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
