Radiator for '71 automatic 6 pack Challenger #252672
03/13/09 02:57 PM
03/13/09 02:57 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
What # is correct for the 6bbl auto Challenger? I don't know if it is an original AC car or not... both #'s would be helpful.
Is it a 26" radiator, or were 24" also used? My buddy says his original was a 24".
Re: Radiator for '71 automatic 6 pack Challenger [Re: PAINT IT BLACK] #252673
03/13/09 03:20 PM
03/13/09 03:20 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
3443959? That's what the '71 parts catalogue comes up with. It shows the same one for the Hemi.
26" core.
Re: Radiator for '71 automatic 6 pack Challenger [Re: PAINT IT BLACK] #252674
03/13/09 04:21 PM
03/13/09 04:21 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Well, It's either an original 6 bbl or A/C, it can't be both. A/C wasn't available with the 6 pack set up as there was not enough clearance between the air cleaner and the compressor. Plus I don't think the A/C compressors like to be spun to 6K + rpm on a regular basis .
Re: Radiator for '71 automatic 6 pack Challenger [Re: superwrench] #252675
03/13/09 05:38 PM
03/13/09 05:38 PM
Houston Texas
Houston Texas
Ouch. I guess it won't come cheaply then.
His car is an original 6 pack car, so no AC. But he says his core support is a 24".... so what's up with that?
Re: Radiator for '71 automatic 6 pack Challenger [Re: PAINT IT BLACK] #252676
03/13/09 05:55 PM
03/13/09 05:55 PM
Houston Texas
Houston Texas
Isn't it either 22" or 26" for muscle applications? Would the opening in his 6 pack car be a 24" opening for a 26" radiator?
Re: Radiator for '71 automatic 6 pack Challenger [Re: PAINT IT BLACK] #252677
03/13/09 05:59 PM
03/13/09 05:59 PM
Mass
charge70 Online content
charge70  Online Content
Mass
Does the Data Tag have "26" at the end of the codes.If not the car may take a 22" rad.My buddy had a 70 Challenger R/T 6 pac car w/a 22" rad.They all didn't get the H.D. cooling system package. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Radiator for '71 automatic 6 pack Challenger [Re: charge70] #252678
03/13/09 06:03 PM
03/13/09 06:03 PM
Houston Texas
Houston Texas
I think his body shop did him the favor of LOSING that tag...!
He says it is supposed to have a 22"... I just don't typically take everything for face value, but he most certainly might be right. What would be the # if it were a 22"?
Re: Radiator for '71 automatic 6 pack Challenger [Re: PAINT IT BLACK] #252679
03/13/09 06:04 PM
03/13/09 06:04 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Steve, all 6bbl 727 3:23 cars had, for the most part, 22" standard rads.. Hoss's '71 v-code Challenger R/T is an original 22" car...
Troy
Troy
Houston Mopar Connection Club
Re: Radiator for '71 automatic 6 pack Challenger [Re: hemi68charger] #252680
03/13/09 06:09 PM
03/13/09 06:09 PM
Houston Texas
Houston Texas
Troy
Ahh... shoulda came to you from the get go!
He says his 26" rad. has been converted to a 4 core and for some reason the fan shroud doesn't clear...? He was asking if I wanted to sell the Bee's 22". I told him not particularly, but I'd find out more about his situation.
Re: Radiator for '71 automatic 6 pack Challenger [Re: PAINT IT BLACK] #252681
03/13/09 06:43 PM
03/13/09 06:43 PM
Houston Texas
Houston Texas
I did some research on line and as luck would have it, Hoss's car calls for the 2998960 radiator. The same # that is on the tank of the Bee's radiator. My Bee calls for a 2998954 radiator, but I'd be willing to go aluminum. I'll see if him and I can work something out. Thanks everyone.
Re: Radiator for '71 automatic 6 pack Challenger [Re: PAINT IT BLACK] #252682
03/14/09 11:51 AM
03/14/09 11:51 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
PIB: Those 2998 960 and 2998 954 rads you list are for 1970 model cars, NOT for 1971 cars, which is what you were originally looking for. The 22" rad you need is 3443 938.
Re: Radiator for '71 automatic 6 pack Challenger [Re: m46rat] #252683
03/14/09 12:33 PM
03/14/09 12:33 PM
Houston Texas
Houston Texas
Yes, good point. I kinda have two threads going regarding the same radiator and this was brought to my attention yesterday on the other thread. Thanks.
