New 4500 TBI EFI systems..... #2526045
07/23/18 08:22 PM
07/23/18 08:22 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I like these....Sombody once told me, they would never make one of these....My car was due for a full re-wiring this winter anyways. Been having all kinds of wierd stuff, and traced it to a bad coil. But that's a story for another day...I want one of these.
https://www.youtube.com/watch?v=yUX7-L0Ehso
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526058
07/23/18 08:44 PM
07/23/18 08:44 PM
I think I would want two of them on a tunnel ram up :devil
After waiting long enough to let some other folks do the debugging of the new systems work
I selected two Acufab 4150 dry 1150 CFM throttle bodies on the 572 C.I. pump gas street hemi motor.
It made 799.6 HP, only 1.397 HP per C.I., I wish now I had selected the bigger 4500 1400 CFM throttle bodies to insure the motor would be making over 800 HP whiney work
The right foot controls the throttle, it seems better to me to have more than enough CFM to make power than to wish I had more work shruggy
Hindsight is till better than my foresight, sometimes whiney
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526072
07/23/18 09:04 PM
07/23/18 09:04 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have a 4500 from ThumperDart. It starts, runs, and drives better than any other carb I have ever had. I would gladly put it up against any of these 'self tuning' throttle body kits for overall drive-ability.
And keep in mind that unless the cam is very, very mild, the idle and low speed 'self tuning' on the EFI will need to be locked out and tuned manually. If a cam with much lope will be used, then the reversions will confuse the EFI and force the manual tune. Just like a carb.
Master, again and still
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526073
07/23/18 09:06 PM
07/23/18 09:06 PM
AndyF Online content
AndyF  Online Content
The built in data logger is a nice feature. What ignition system are you running? If you are using a distributor then you might consider switching to the Holley Hyperspark unit. That will avoid some potential RF issues and it will give you an easier way to control the ignition timing.
Re: New 4500 TBI EFI systems..... [Re: DaveRS23] #2526096
07/23/18 09:52 PM
07/23/18 09:52 PM
Dragula Offline OP
Dragula  Offline OP
I have two of his carbs....Both are excellent. But my one engine is big, and has a weird cam. Very tough to dial in.
Also not my first use of efi...
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526115
07/23/18 10:26 PM
07/23/18 10:26 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
That is pretty cool
Re: New 4500 TBI EFI systems..... [Re: DaveRS23] #2526119
07/23/18 10:30 PM
07/23/18 10:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thank you and so will I............. whistling
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526150
07/23/18 11:28 PM
07/23/18 11:28 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Just bolted one on my car
Only driven about a half a mile, alternator was out and ran out of juice in my uncharged battery
when I firsted cranked it, idle was at 17 to 1 afr but within about 20 seconds it had it down to 13.9 to 1
On vacation now and can’t wait to get it back to play with it. Headed to Drag Week this year with it so we will see how it does
Re: New 4500 TBI EFI systems..... [Re: mprhound] #2526160
07/23/18 11:49 PM
07/23/18 11:49 PM
Dragula Offline OP
Dragula  Offline OP
Did you get the 4500?
I am having issues with getting my cruising AFR with my carb to a reasonable level. Tried a lot of stuff, and its not come around.
Been thinking about a pair of the eddy 800 Thunder series until I saw this. Buddy of mine mine just bolted a set on his big hemi, and they were pretty good on his combo out of the box.
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526193
07/24/18 12:54 AM
07/24/18 12:54 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
We can get the carb to come around no problem just hit me up and I will see what we can do to fix whatever it's doing you don't like.........We need to play the emulsion game now and see what that does cos it's VERY eye opening.......... thumbs
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526196
07/24/18 01:00 AM
07/24/18 01:00 AM
If you switch over to the Sniper you'll be surprised with how many other problems it can help you solve. Being able to push a button and download all of the sensor information is a big help in sorting stuff out.
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526245
07/24/18 02:45 AM
07/24/18 02:45 AM
Texas
mprhound Offline
mprhound  Offline
Texas
[quote=Dragula]Did you get the 4500?
Yes I got the 4500
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526260
07/24/18 07:13 AM
07/24/18 07:13 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
I'm willing to bet that with systems like this, Holley will stop manufacturing carburetors all together.
Re: New 4500 TBI EFI systems..... [Re: STEFF] #2526352
07/24/18 12:54 PM
07/24/18 12:54 PM
Or at least scale it way back. Most of the car guys I talk to don't really understand the benefits of EFI yet so it will take a few more years before it becomes accepted.
Rich was a real pioneer with this stuff so I'm sure he has a lot more stories than the rest of us. I know he converted some just by beating them at the track. Once they saw how much better EFI worked they started to switch.
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526400
07/24/18 02:01 PM
07/24/18 02:01 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My son is REALLY wanting to put one on the Dragster. Me not so much. But I'm willing to bet he will do it. Should be interesting to see how it stacks up against the carb in terms of performance on a 1000+HP BB
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526441
07/24/18 03:14 PM
07/24/18 03:14 PM
WOT performance should be roughly equal if both units are in proper working condition. The advantage I see for a bracket car is that the EFI setup would probably be better around the pits and in the lane. Easier to start, easier to drive around the pits, etc. And the EFI setup would eliminate the time spent changing jets as the weather changes. The built in weather station is kind of cool too.
Re: New 4500 TBI EFI systems..... [Re: STEFF] #2526522
07/24/18 06:20 PM
07/24/18 06:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Never happen................. drive
Re: New 4500 TBI EFI systems..... [Re: Al_Alguire] #2526573
07/24/18 07:45 PM
07/24/18 07:45 PM
Dragula Offline OP
Dragula  Offline OP
I was pretty impressed with this vid..
https://www.youtube.com/watch?v=QbHW7bHXvAk
When I got into efi back in the 90's, these systems were so manual and had so little extra functions....Now a days, a simple TBI system can do so much, its amazing....Check out the list of features, just amazing.
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526576
07/24/18 07:48 PM
07/24/18 07:48 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
If anyone needs any of of the Holley efi systems, or any Holley brand part, we are direct with them and dropship everyday. Mike
mr2performance@sbcglobal.net
MR2PERFORMANCE RACE CARS 765 483 9371
Re: New 4500 TBI EFI systems..... [Re: Dragula] #2526760
07/25/18 09:12 AM
07/25/18 09:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That last video was pretty cool. It's amazing what all this newer stuff can do, then step over to the port injection side and the options and capabilities are almost unlimited.
68 Barracuda Formula S 340
