Race trailer tires, I HATE them!
#2526103
07/23/18 10:04 PM
07/23/18 10:04 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
I took my 1969 Dart GTS H code 4 speed car to Woodburn Sunday morning along with a lot of other parts to try selling them at the annual Mopar car show, race and swap meet, it didn't sell On the way back late yesterday afternoon I got stopped by a Oregon State trooper who informed me that they had receive several calls on my trailer having a blown tire on the right side I do pass slower cars going or coming back from the race The right front Tow King brand E rated tire was indeed shredded The right rear E rated Tow Master brand tire had thrown the tread but was still holding air, THANKS to GOD I had felt some bumping for short while, maybe three or four minutes, back about twelve miles before being stopped so I'm really lucky it didn't cause more damage to me or the truck and trailer coming over the Cascade Mountains over on Santiam pass I've had more trailer tire trouble than I can remember on all three race trailers I've own in the last 20 yrs. I've also had some tires blow out on one of my 1 ton car hauler years ago also so I don't know the answer to tire problems on race trailers or car hauler trucks that sit a lot and don't get used a lot I bought four new Maxis Brand ten ply rated trailer tires (made in India, not the U.S. ) for the trailer several months ago, I had two of them mounted up as spares ready to run in the trailer so I put one of them on the back axle because I couldn't break the lug nuts loose on the front rim with the hand tools I carry it the trailer tool box I think all of the tires on the trailer are around 4 yrs old or a maybe a little over that I was less than 6 miles from home so I limped it home to finish changing the other three of the old tires on the trailer to the new ones now I had thought about changing both of the left side tires on Saturday in case I had troubles with them, but I didn't Most of the road from Bend to Salem is two lane highway with wide shoulders but it is not real safe to be changing tires on the side of the road, especially on the driver sides of any vehicle Be safe, when in doubt, change them out Just like race parts
Re: Race trailer tires, I HATE them!
[Re: Cab_Burge]
#2526105
07/23/18 10:09 PM
07/23/18 10:09 PM
birdtracker
Cab: if they are 16 inch rims look at Bridgestone Duravis tires. I worked on a fleet of pickups with trailers. These ended our tire problem and are very competetively priced. Also get rid of the rubber valve stems and use bolt in ones. Birdtracker
[Re: birdtracker]
#2526107
07/23/18 10:14 PM
07/23/18 10:14 PM
Cab_Burge
My trailer has 15 inch rims, I should have bought six lug 16 inch rims and tires years ago, huh My next trailer, if that happens, will have 16 inch rims and tires for sure
[Re: Cab_Burge]
#2526124
07/23/18 10:35 PM
07/23/18 10:35 PM
dartman366
Mt. Vernon, Ohio
one of the best ways to extend the life of your trailer and tow vehicle tires is to keep them covered and out of the weather while not in use, and remove them or cover them in the winter months, also if the for winter storage park the trailer on wooden planks and not on the dirt or gravel driveway, I jack mine up to take most or all of the weight off the tires and cover them for the winter this go's for the motorhome also.
[Re: '72CudaRacer]
#2526201
07/24/18 01:09 AM
07/24/18 01:09 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
42 years of towing and I’ve had tire issues 3 times with lots of towing in pa and Ohio. 15 inch tires and buy new ones every 4-5 years. Never taken off during the winter and parked on gravel but I do inflate them 10 pounds over the poundage listed on the tire. My new trailer I bought last year has been updated to 16 inch tires.
[Re: Cab_Burge]
#2526221
07/24/18 01:58 AM
07/24/18 01:58 AM
Posts: 8,325 fredericksburg,va
cudaman1969
fredericksburg,va
In 45 years of towing trailers, nether I nor my buddy's have ever had a blow out. (Knock on wood) the enclosed trailer I have now is the only one with a "trailer" tire on it. The first set just fell apart sitting in the yard after three years of not using. Second set now has me afraid they're going to do the same thing, possibly at speed. One dude told me to use LT tires, he had switched and had no more problems. He said if he gets pulled over a gets a ticket it's still cheaper than exploding tires and tearing up the trailer. Something about side loading of trailer tires don't work where as LT tires are made to handle that. By the way, we only used truck tires on our early trailers too.
[Re: Cab_Burge]
#2526229
07/24/18 02:12 AM
07/24/18 02:12 AM
Posts: 10,222 Someplace you aren't
SomeCarGuy
LT tires flex so you have a good ride. Take 11% off your load rating when running those instead of the stuff wall ST tires. LTs will run hotter with the flexing.
I want my fair share
[Re: Sport440]
#2526313
07/24/18 11:47 AM
07/24/18 11:47 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Definitely over inflate them by a little bit by 10#s or so. I’m not going to “over inflate” my trailer tires.... especially if I’m leaving town this time of year where ambient temps are 110+ and the road temps reach 150. That and along with the dry climate is trailer tire he77 my friends. I usually run 80-85 (95 max) on my current set of Load Star (Kenda) 16” ST tires. The 2 spares I now have are G (110 max). The tires alone are over 50lb. I’ll buy two more next year and rotate them on to the trailer and keep 2 of the old tires for spares. Those tires actually rate higher than the wheels they’re on. I still find it difficult to keep tires more than 3 years down here. I keep them covered with those white lined covers that stretch over the tires. When I had 15” tires, I was lucky to get 2. My biggest prob is that I had one tire that used to run 10-12 degrees warmer than the rest. “IF”....well, when I’d lose a tire it would be that one. Of course the next one would be the poor single tire that took the brunt of the load while the other one was dying. I ended up finding a trailer repair place and had the measuring points from cargo mate in hand. We ended up replacing one axle and upgraded the leaf springs hardware to a newer Dexter design that is fully greasable. So far 2400 miles and perfect tire wear and dead even tire temps. https://www.etrailer.com/Trailer-Suspension/Dexter-Axle/K71-653-00.html
[Re: dart games]
#2526342
07/24/18 12:45 PM
07/24/18 12:45 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If guys are having trouble with 15 inch tires on an open trailer you better look for other issues. Shouldn’t happen. Heck my first trailer had mobile home tires on it that I paid 20.00 for mounted and they even lasted on an open trailer and they were made for a one way trip to set the mobile home.
[Re: pittsburghracer]
#2526364
07/24/18 01:10 PM
07/24/18 01:10 PM
Posts: 2,836 Connecticut
FurryStump
Connecticut
42 years of towing and I’ve had tire issues 3 times with lots of towing in pa and Ohio. 15 inch tires and buy new ones every 4-5 years. Never taken off during the winter and parked on gravel but I do inflate them 10 pounds over the poundage listed on the tire. My new trailer I bought last year has been updated to 16 inch tires. 10lbs makes a world of difference!
[Re: FurryStump]
#2526405
07/24/18 02:06 PM
07/24/18 02:06 PM
Cab_Burge
I was told by a commercial Cooper tire dealer to always inflate any tire to 5 lbs. above the sidewall rating, he was in Victorville, CA in the Mojave desert near J I do that on all my trailer and truck tires, works fine for me except them dang trailer tires coming apart I looked last night for E or G rated LT 15 inch tires on Summit, I didn't find any and there is no way I'm putting C or D load rated tires on my trailer I have weighed the trailer multiple times loaded and unloaded, max weight has been 8640 Lbs. on the axles and adding 700 Lbs. on the rear truck axle while removing 300 Lbs. off the front truck axle with my old Duster
[Re: Cab_Burge]
#2526632
07/24/18 10:25 PM
07/24/18 10:25 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
I'm trying the new Goodyear Endurance - Size: ST225/75R15 will see if they hold up.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
