Re: Stage VI replacement guides
[Re: Hutch]
#2526078
07/23/18 09:26 PM
07/23/18 09:26 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The original guides are .494” OD.
I just ream the holes to .500” and use std .502” guides.
[Re: Hutch]
#2526094
07/23/18 09:49 PM
07/23/18 09:49 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Now there's a guy that works these all the time and is here to answer many members questions.Also can pick the right cam for the right combo! Ports heads and can flow test.A good place to sent your heads!!
[Re: Hutch]
#2526354
07/24/18 12:55 PM
07/24/18 12:55 PM
fast68plymouth
So. Burlington, Vt.
Sounds like the heads are off for servicing......... look close for signs of the seats moving around while they’re apart and clean. Pretty common on stage 6’s.
