Page 1 of 4 1 2 3 4
Ritter racing block design flaw #2525334
07/22/18 02:09 PM
07/22/18 02:09 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
As many of you may know we have been struggling with an internal water leak on this block since it was new.. causing premature hone damage.. that being said when it runs it runs strong. This is a naturally aspirated engine.. that lives in an extremely harsh environment and it's put to the test every pass.. we tore the engine down to clean install some epoxy in the block And hone.. upon disassembly we noticed the block was cracked at the three Center cam bearings.. the block is extremely thin there because of its design it is approximately approximately 7/16 of an inch wide from the bearing register to the oil drain Passage..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Ritter racing block design flaw [Re: WHITEDART] #2525335
07/22/18 02:14 PM
07/22/18 02:14 PM
bean town ....Ca
W
W
bean town ....Ca
Re: Ritter racing block design flaw [Re: WHITEDART] #2525337
07/22/18 02:16 PM
07/22/18 02:16 PM
bean town ....Ca
W
W
bean town ....Ca
Couple more pics
Re: Ritter racing block design flaw [Re: WHITEDART] #2525339
07/22/18 02:20 PM
07/22/18 02:20 PM
bean town ....Ca
W
W
bean town ....Ca
I am no engineer however it appears. The way the cam tunnel is closed off from the top and open on the bottom there is a significant amount of movement that's taking place causing a crack in these thin areas.. the cracks were not visible to the eye until this go around.. however the motor would not hold cam bearings very well since day one.. which tells me they have always been there and probably open up with heat causing the bearings to lose their press.. this application is a 55 mm cam
Re: Ritter racing block design flaw [Re: WHITEDART] #2525342
07/22/18 02:23 PM
07/22/18 02:23 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
WD...ever thought bout trying one of the newer casting blocks?
Re: Ritter racing block design flaw [Re: racerx] #2525344
07/22/18 02:27 PM
07/22/18 02:27 PM
bean town ....Ca
W
W
bean town ....Ca
The motor would not hold cam bearings until I made these retainers.. this image will kind of give you an idea of what the design of the cam and Valley area look like
Re: Ritter racing block design flaw [Re: racerx] #2525346
07/22/18 02:29 PM
07/22/18 02:29 PM
bean town ....Ca
W
W
bean town ....Ca
only if someone gave me one for free and all the machine work was done to my specs and it wouldn't cost me a dime .. FYI this is a second generation Ritter block.. this is neither a casting or Machining flaw it is structural
Re: Ritter racing block design flaw [Re: WHITEDART] #2525352
07/22/18 02:36 PM
07/22/18 02:36 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
curios to know , how many pass's on this block?
Re: Ritter racing block design flaw [Re: racerx] #2525357
07/22/18 02:43 PM
07/22/18 02:43 PM
bean town ....Ca
W
W
bean town ....Ca
150ish mostly 1/8 Mile.
Re: Ritter racing block design flaw [Re: WHITEDART] #2525366
07/22/18 02:56 PM
07/22/18 02:56 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
gotcha…. up I remember there were a lot of issues with that block when it was first cast.
so what are the plans now?
Re: Ritter racing block design flaw [Re: racerx] #2525371
07/22/18 03:08 PM
07/22/18 03:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Very sorry to hear this
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ritter racing block design flaw [Re: WHITEDART] #2525383
07/22/18 03:51 PM
07/22/18 03:51 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
VERY disappointing, just more junk made for mopars. very sorry for you WD
Re: Ritter racing block design flaw [Re: CSK] #2525395
07/22/18 04:14 PM
07/22/18 04:14 PM
Washington
madscientist Offline
Washington
Junk? Really? I've seen almost every brand of block crack there.
Re: Ritter racing block design flaw [Re: CSK] #2525396
07/22/18 04:19 PM
07/22/18 04:19 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Have you show this to Ritter?
Re: Ritter racing block design flaw [Re: Skeptic] #2525400
07/22/18 04:26 PM
07/22/18 04:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That would be an exercise in futility
Re: Ritter racing block design flaw [Re: WHITEDART] #2525418
07/22/18 04:47 PM
07/22/18 04:47 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I hate reading this kinda stuff!!Have they come out with a new and improved block? Who else makes an aftermarket block for the W8??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Ritter racing block design flaw [Re: Al_Alguire] #2525426
07/22/18 05:04 PM
07/22/18 05:04 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
If you are expecting a refund or exchange, sure. They can't fix-or be expected to fix, problems they don't know about. Sending an e-mail with a few pictures isn't really much "exercise".
Re: Ritter racing block design flaw [Re: hemi-itis] #2525438
07/22/18 05:33 PM
07/22/18 05:33 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You can get an aluminum A8 block in a week if you are willing to part with $7000.00
Then buy the needed timing set for another 1000.... but you can get it.
Re: Ritter racing block design flaw [Re: WHITEDART] #2525450
07/22/18 05:54 PM
07/22/18 05:54 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Just out of curiosity, how much is it bored for the 55mm bearings?
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Ritter racing block design flaw [Re: WHITEDART] #2525462
07/22/18 06:14 PM
07/22/18 06:14 PM
hemi-itis Offline
hemi-itis  Offline
Are the lifter bushings tall due to shallow lifter boss or for el notcho lifters?
Page 1 of 4 1 2 3 4
