Page 1 of 4 1 2 3 4 >
#2525334 - 07/22/18 12:09 PM Ritter racing block design flaw
WHITEDART Offline
Loc: bean town ....Ca
As many of you may know we have been struggling with an internal water leak on this block since it was new.. causing premature hone damage.. that being said when it runs it runs strong. This is a naturally aspirated engine.. that lives in an extremely harsh environment and it's put to the test every pass.. we tore the engine down to clean install some epoxy in the block And hone.. upon disassembly we noticed the block was cracked at the three Center cam bearings.. the block is extremely thin there because of its design it is approximately approximately 7/16 of an inch wide from the bearing register to the oil drain Passage..
Edited by WHITEDART (07/22/18 12:16 PM)
In the 8s N/A.with Brett miller W8's
5.42 8.52 159.
#2525335 - 07/22/18 12:14 PM Re: Ritter racing block design flaw [Re: WHITEDART]
WHITEDART Offline
5.42 8.52 159.
#2525337 - 07/22/18 12:16 PM Re: Ritter racing block design flaw [Re: WHITEDART]
WHITEDART Offline
Couple more pics
5.42 8.52 159.
#2525339 - 07/22/18 12:20 PM Re: Ritter racing block design flaw [Re: WHITEDART]
WHITEDART Offline
I am no engineer however it appears. The way the cam tunnel is closed off from the top and open on the bottom there is a significant amount of movement that's taking place causing a crack in these thin areas.. the cracks were not visible to the eye until this go around.. however the motor would not hold cam bearings very well since day one.. which tells me they have always been there and probably open up with heat causing the bearings to lose their press.. this application is a 55 mm cam
5.42 8.52 159.
#2525342 - 07/22/18 12:23 PM Re: Ritter racing block design flaw [Re: WHITEDART]
racerx Offline
Loc: Mo.
WD...ever thought bout trying one of the newer casting blocks?
#2525344 - 07/22/18 12:27 PM Re: Ritter racing block design flaw [Re: racerx]
WHITEDART Offline
The motor would not hold cam bearings until I made these retainers.. this image will kind of give you an idea of what the design of the cam and Valley area look like
5.42 8.52 159.
#2525346 - 07/22/18 12:29 PM Re: Ritter racing block design flaw [Re: racerx]
WHITEDART Offline
only if someone gave me one for free and all the machine work was done to my specs and it wouldn't cost me a dime .. FYI this is a second generation Ritter block.. this is neither a casting or Machining flaw it is structural
Edited by WHITEDART (07/22/18 12:30 PM)
5.42 8.52 159.
#2525352 - 07/22/18 12:36 PM Re: Ritter racing block design flaw [Re: WHITEDART]
racerx Offline
Loc: Mo.
curios to know , how many pass's on this block?
#2525357 - 07/22/18 12:43 PM Re: Ritter racing block design flaw [Re: racerx]
WHITEDART Offline
150ish mostly 1/8 Mile.
5.42 8.52 159.
#2525366 - 07/22/18 12:56 PM Re: Ritter racing block design flaw [Re: WHITEDART]
racerx Offline
Loc: Mo.
gotcha…. up I remember there were a lot of issues with that block when it was first cast.
so what are the plans now?
Edited by racerx (07/22/18 12:57 PM)
#2525371 - 07/22/18 01:08 PM Re: Ritter racing block design flaw [Re: racerx]
pittsburghracer Offline
"Little"John
Loc: PA.
Very sorry to hear this
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Untitled by John Cadamore, on Flickr
#2525383 - 07/22/18 01:51 PM Re: Ritter racing block design flaw [Re: WHITEDART]
csk Offline
Loc: KATY TEXAS
VERY disappointing, just more junk made for mopars. very sorry for you WD
Edited by csk (07/22/18 01:55 PM)
LINK TO MY STORY http://www.onallcylinders.com/2015/11/16...-dodge-charger/
[url=https://flic.kr/p/Xdr9rm]
Daily driver 512ci,9.7to1 Stealth heads A518trans,3.54gear 4050lb,11.33@121.1,1750DA full street car trim.
#2525395 - 07/22/18 02:14 PM Re: Ritter racing block design flaw [Re: csk]
madscientist Offline
Loc: Washington
Junk? Really? I've seen almost every brand of block crack there.
#2525396 - 07/22/18 02:19 PM Re: Ritter racing block design flaw [Re: csk]
Skeptic Offline
Loc: The Pale Blue Dot
Have you show this to Ritter?
"Talking tough is easy when it's other people's evil and you're judging what they do or don't believe" Mike Cooley / Drive-By Truckers © Razor and Tie Music (BMI)
#2525400 - 07/22/18 02:26 PM Re: Ritter racing block design flaw [Re: Skeptic]
Al_Alguire Offline
Loc: Las Vegas
That would be an exercise in futility
#2525418 - 07/22/18 02:47 PM Re: Ritter racing block design flaw [Re: WHITEDART]
hemi-itis Online   content
Loc: Great Neck,LI,new york
I hate reading this kinda stuff!!Have they come out with a new and improved block? Who else makes an aftermarket block for the W8??
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
#2525426 - 07/22/18 03:04 PM Re: Ritter racing block design flaw [Re: Al_Alguire]
Skeptic Offline
If you are expecting a refund or exchange, sure. They can't fix-or be expected to fix, problems they don't know about. Sending an e-mail with a few pictures isn't really much "exercise".
#2525438 - 07/22/18 03:33 PM Re: Ritter racing block design flaw [Re: hemi-itis]
TRENDZ Offline
Loc: Milwaukee WI
You can get an aluminum A8 block in a week if you are willing to part with $7000.00
Then buy the needed timing set for another 1000.... but you can get it.
#2525450 - 07/22/18 03:54 PM Re: Ritter racing block design flaw [Re: WHITEDART]
oldiron Offline
Loc: New Hampshire, USA
Just out of curiosity, how much is it bored for the 55mm bearings?
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
#2525462 - 07/22/18 04:14 PM Re: Ritter racing block design flaw [Re: WHITEDART]
Are the lifter bushings tall due to shallow lifter boss or for el notcho lifters?
25,688 Registered Members
196,636 Topics
Correct Front Wheel Cylinders for 10" Drum on an A-Body?
by vinnyd76
26 minutes 39 seconds ago
Long rams
by 67R/T4speeder
36 minutes 8 seconds ago
Bye Tappen Zee bridge
by bigdad
Today at 08:33 AM
Anyone have their 8 track tapes reburbished?
by Charger446
Today at 08:30 AM
