Looking for inexpensive substitute for seam sealer #252528
03/13/09 12:35 PM
03/13/09 12:35 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hey, anyone use anything other than the seam sealers available from local auto stores? Like chaulk from Home Depot?
Re: Looking for inexpensive substitute for seam sealer [Re: cudabitten] #252529
03/13/09 02:12 PM
03/13/09 02:12 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
I used DAP tub/tile to seal my wheel tubs after installation.Primed first,applied caulk and let dry.Then painted color coat.Has lasted ten plus years. Chris
Re: Looking for inexpensive substitute for seam sealer [Re: BADDART] #252530
03/13/09 02:24 PM
03/13/09 02:24 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
The 3-M fast and firm is not so good it cracks when it dries out and srinks plenty.
Next car will get the 2 part Fusor{sp?} Little extra cash is worth it to have good supplies
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Looking for inexpensive substitute for seam sealer [Re: cudabitten] #252531
03/13/09 03:17 PM
03/13/09 03:17 PM
qc
mxbeep Offline
mxbeep  Offline
qc
i have used many times exterior household sealer.
Once metal work is done and primered prior to paint.
Apply it first with silicone gun gun and follow up with a paint brush.
I soak the paint brush whiskers in thinner prior to spreading the seam sealer.( it spreads easier)
Once painted it looks very close to OEM,
Ive done this method several times for the last 10 years and never as one cracked.
Not to mention some of these cars are stored in unheated garages .
Re: Looking for inexpensive substitute for seam sealer [Re: cudabitten] #252532
03/14/09 09:49 AM
03/14/09 09:49 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Vulkem. It's a polyurethane sealer that comes in standard size (11 oz?) caulk tubes for around $5.00 at my local lumber yard. Sticks to anything as long as it's clean and lasts indefinately. Just make sure you put everything where you want it 'cuz it DOES NOT come off.
Re: Looking for inexpensive substitute for seam sealer [Re: cudabitten] #252533
03/15/09 10:56 AM
03/15/09 10:56 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Caulk probably wouldn't the best thing since most are latex or silicone but I have had good luck with a 3M polyurethane sealer for roofs/gutters that is paintable and dries flexible, I think it was around $8 a tube at home depot.
When it dries it's about the same firmness as 3M seam sealer but is black in color instead of tan/beige.
Re: Looking for inexpensive substitute for seam sealer [Re: MoparJoe] #252534
03/15/09 11:02 AM
03/15/09 11:02 AM
IN
ahy Offline
ahy  Offline
IN
Butyl rubber caulk sold as gutter seal works well if you have time to let it set. It takes several days to skin over so you can paint it. Polyurethane roof sealer is faster as posted above. The "seam seal" from the parts stores - at least autozone - is junk. It shrinks and cracks.
Re: Looking for inexpensive substitute for seam sealer [Re: ahy] #252535
03/15/09 11:18 AM
03/15/09 11:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Liquid nails work well. run a bead then take your finger and smooth it out some (use rubber gloves) Let it dry and you can paint it. I've also sanded it, but it's much harder than bondo when it dries. Make sure you get the kind for metal.
Re: Looking for inexpensive substitute for seam sealer [Re: MoparJoe] #252536
03/15/09 01:06 PM
03/15/09 01:06 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Used this on the Fury and it worked well.
Re: Looking for inexpensive substitute for seam sealer [Re: cudabitten] #252537
03/15/09 10:14 PM
03/15/09 10:14 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
How cheap can you be ?!?!?!? I could understand trying to save a buck if you needed a couple hundred tubes !!!
Re: Looking for inexpensive substitute for seam sealer [Re: Stanton] #252538
03/16/09 01:04 AM
03/16/09 01:04 AM
Jacksonville Florida
elitecustombody Offline
+1
