Battery n trunk cable routing? #2523254
07/17/18 08:40 PM
07/17/18 08:40 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Well I plan on going under the carpeting, but was wondering if there would be a problem passing tech with the 1/0 battery cable secured to the floor on top of the carpeting? Like on the side of the hump.
Re: Battery n trunk cable routing? [Re: GoDartGo] #2523256
07/17/18 08:48 PM
07/17/18 08:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Run it under the car.. if you want follow the
frame rail
wave
Re: Battery n trunk cable routing? [Re: GoDartGo] #2523261
07/17/18 09:13 PM
07/17/18 09:13 PM
What year and body style are you working on?
I run mine under the door sill plates under the carpet or floor mats on the passenger side of the car up to and then under the kick panels in front of the doors and then up behind the dash and then into the engine compartment so all of the cable is out of sight except in the trunk and engine compartment work up twocents
I mount my batteries as far back as possible on the passenger side as close to the outside sheet metal that I can get ii safely mounted wrench up
Re: Battery n trunk cable routing? [Re: GoDartGo] #2523287
07/17/18 10:11 PM
07/17/18 10:11 PM
GoDartGo Offline OP
GoDartGo  Offline OP
'71 Scampdart. Any thoughts on making a 1/0 pig tail from the starter, to plug into the cable at a reachable spot and not behind the headers?
Re: Battery n trunk cable routing? [Re: GoDartGo] #2523295
07/17/18 10:25 PM
07/17/18 10:25 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I keep all the electrical stuff inside the car. Main cable runs up through the car to a junction where it is distributed as needed.
Re: Battery n trunk cable routing? [Re: CMcAllister] #2523329
07/17/18 11:15 PM
07/17/18 11:15 PM
fullmetaljacket Offline
Mine after coming off the battery runs along the continental shelf of the trunk floor by the lower quarters and then hugs the passenger wheel wells up to the rear well valley hump and across to the drivers side and into the cars interior. From there it runs along the floors edge and under the sill plates up to the kick panel area under the kick panel covers and then ends at a junction box half way up the inner firewall. On the engine side of the firewall, it snakes down very tightly down to the starter stud.
Aluminum cable strand for a lightweight set up. Heat shrink sealed ends for trouble free operation out in the elements.
Re: Battery n trunk cable routing? [Re: GoDartGo] #2524380
07/20/18 05:03 AM
07/20/18 05:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run my cable under my carpet through my car. What I did was put the starter on a Ford type starter solenoid that's in my trunk. So that way the large battery cable to the starter is only hot when cranking the eng. Then I run an 8 gage wire from the battery to the starter relay on the firewall where my car picks up its hot feed for everything. That also is under the carpet but I use a 70 amp fuse in a fuse holder bolted to the battery pos post as I wanted that fused and my alt output goes into that wire also. My 63 has been like that since 2006 so far and never a problem. You can just see the starter solenoid in front of the battery case. Ron
Re: Battery n trunk cable routing? [Re: GoDartGo] #2524387
07/20/18 07:17 AM
07/20/18 07:17 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I made tabs so the cable runs along the upper RH 1/4 panel. Glued the tabs on with Plexus to the trunk gutter. Then over the tub and along the right door sill under the carpet. It terminates at a firewall pass thru near the gas pedal. That way you don't see it laying in the trunk.
Doug
Re: Battery n trunk cable routing? [Re: fullmetaljacket] #2524453
07/20/18 11:31 AM
07/20/18 11:31 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
This is pretty much how mine is ran.
Re: Battery n trunk cable routing? [Re: dvw] #2524457
07/20/18 11:37 AM
07/20/18 11:37 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug
Doug, how did you do the lever/handle for the battery cutoff switch, inside the car?
Jeff
69 GTX 68 Road Runner
Re: Battery n trunk cable routing? [Re: GoDartGo] #2524531
07/20/18 02:00 PM
07/20/18 02:00 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The linkage in the trunk is made from 3/8"fuel line tubing. Its held to the switch with a compression fitting cut in half. Bought the Morse cable and tabs on line for about $45. Made lever out of aluminum that attaches to a bar in the cage.
Doug
Re: Battery n trunk cable routing? [Re: GoDartGo] #2524541
07/20/18 02:19 PM
07/20/18 02:19 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Any pictures of how it is mounted in the passenger area?
Re: Battery n trunk cable routing? [Re: JERICOGTX] #2524890
07/21/18 09:34 AM
07/21/18 09:34 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Inside
