Attn: Jim at Detroit Muscle Technologies #2491988
05/04/18 02:35 PM
05/04/18 02:35 PM
md
mopars4ever Online content OP
mopars4ever  Online Content OP
md
I was wondering if you will make a better third light gasket for the later model Dodge Rams? It seems all of them leak over time. I`m sure you would sell a ton of them. Most people are making there own but it would be nice to have one that it cut to fit. Thanks
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524336
07/20/18 01:34 AM
07/20/18 01:34 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
How did I miss this and what years are we talking about?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524338
07/20/18 01:38 AM
07/20/18 01:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have heard that this is a major issue.
I'm guessing it's on the 2003 and up
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524425
07/20/18 10:34 AM
07/20/18 10:34 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Yes, mine leaks also.
I Park the truck up hill just to keep the headliner from staining
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Attn: Jim at Detroit Muscle Technologies [Re: moparts] #2524528
07/20/18 01:52 PM
07/20/18 01:52 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Yikes.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524609
07/20/18 04:00 PM
07/20/18 04:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I believe the issue is with the 09-18 models. I haven't had a problem yet with my 14. The lights have a screw at each end but the center does not. The housing has some flex to it so it doesn't push up tight to the body. At least that's what it looked like to me when I took mine out to change the bulb.
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524623
07/20/18 04:37 PM
07/20/18 04:37 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
My 2000 leaked. They told me to silicone it - I did and that solved the problem.
Re: Attn: Jim at Detroit Muscle Technologies [Re: burdar] #2524624
07/20/18 04:38 PM
07/20/18 04:38 PM
Mass
charge70 Offline
charge70  Offline
Mass
My 05 Daytona leaks water thru the 3rd brake lite,so the problem is earlier than 09.After Googling this it seems that this is a real common problem with these trucks.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524626
07/20/18 04:49 PM
07/20/18 04:49 PM
md
md
I noticed on the newer Rams the gasket tends to shrink over time and cause the leak.
Re: Attn: Jim at Detroit Muscle Technologies [Re: 71TA] #2524629
07/20/18 04:52 PM
07/20/18 04:52 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I don't know about the newer ones, but it started in 1994. I've always just assumed they'd solved it at some point, apparently not.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524632
07/20/18 05:00 PM
07/20/18 05:00 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
'02-up 1500s and '03-up 2500s leak there. My '06 did. Made a new gasket like others. I also found something about sealing the rear window... shruggy
Don't know about earlier Rams. work
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524639
07/20/18 05:11 PM
07/20/18 05:11 PM
Missouri
randavis Offline
randavis  Offline
Missouri
My 13 leaks at the sliding rear window. I haven't figured out how to stop that yet. The water runs down to the well under the rear seat on the passenger side. I have a sponge in there to absorb it.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524691
07/20/18 07:33 PM
07/20/18 07:33 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Literally 1,000 threads on any of the Ram Forums
I caught my 2011 early - Filled up the storage area with water behind the drivers seat , under the rear seat during a down poor literally brand new
I gutted the interior and dried everything out - Lucky my headliner was untouched
I already knew what the dealer fix under warranty was
So Metro self stick weatherstripping at Autozone has worked awesome ever since , just clean and scrape off the cheap gasket first off the third brake light
I cant believe dealers where actually using silicone adhesive or just replacing the third brake light with the crap gasket over again
On the sliding rear window all I had to do was blow out the three water channels under the bottom seal with compressed air
Two of them where filled with black adhesive from the factory so the water could never escape
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524698
07/20/18 07:42 PM
07/20/18 07:42 PM
md
md
Yea, silicone sucks when you have to service the light.
Re: Attn: Jim at Detroit Muscle Technologies [Re: 71TA] #2524767
07/20/18 09:50 PM
07/20/18 09:50 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
To be honest I think it's Generations 2, 3 and 4 with Gen 3 and 4 being the worst.
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2524923
07/21/18 11:42 AM
07/21/18 11:42 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Same thing for a 2008 Raider (Dakota). One day I notice the stains on the headliner. I made a gasket and siliconed it. But a new gasket woukd have been nice. (PS, Mitsubishi Raider 2005-2009 is just rebaged Dakota)
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2525266
07/22/18 11:36 AM
07/22/18 11:36 AM
STL
cdstl Offline
cdstl  Offline
STL
On the Second Gens, 1994-2001. I take a strip of foam weather strip and run it continuously from the bottom of one side up and over the top to the bottom of the other side. Then I run a strip along the bottom.
Seems to work.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2525372
07/22/18 03:12 PM
07/22/18 03:12 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Jim, if you make some good ones that do the trick, I'll take one.
-Eric
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2525666
07/23/18 12:40 AM
07/23/18 12:40 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I'm in. 2014 Ram Express. TIA
Common sense is a flower that does not grow in everybody's garden
Re: Attn: Jim at Detroit Muscle Technologies [Re: mopars4ever] #2525743
07/23/18 09:05 AM
07/23/18 09:05 AM
Mass
charge70 Offline
charge70  Offline
Mass
I'm in also.2005 Dodge Daytona.
