A body's w/ ladder bars?? #252423
03/13/09 11:16 AM
03/13/09 11:16 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Do anyone of you have pictures of your Ladder bar/coil over set-up on your A-bodies w/ stock frame rails? Did you have to cut the floor? I'm getting ready to do the install on my 66 dart and its easier to get ideas from pictures of others who have done it.
Any pointers for a first timer?
Re: A body's w/ ladder bars?? [Re: mopowers] #252424
03/13/09 11:24 AM
03/13/09 11:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How many holes in the front mount, most of the time you
cant get the bar angle low enough. Try to set up the
front so at least the bottom hole will give you a
downward angle of a few degrees. You will need good
adjustable shocks for the rear to control the body
seperation
Re: A body's w/ ladder bars?? [Re: MR_P_BODY] #252425
03/13/09 11:37 AM
03/13/09 11:37 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The Valiant had stock frame rails and ladder bars. I used the RJ race cars bars, had to cut very little from the rear floor but I wanted the front crossmember as high as possible in the car. So I had to trim out a small section up front to allow for placement of the upper bolt hole, knowing I would never use it anyway but it put the crossmember high in the car. The car was mini tubbed with a 28x10.50 slick with room to spare. Here is a pic or two.
Re: A body's w/ ladder bars?? [Re: mopowers] #252426
03/13/09 11:40 AM
03/13/09 11:40 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you look real close in this picture you can see the small area cut for the crossmember. It is just in front of the seat and next to the rail and kicker..
Re: A body's w/ ladder bars?? [Re: MR_P_BODY] #252427
03/14/09 12:03 AM
03/14/09 12:03 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
seperation
I haven't bought the stuff yet. I've been looking at the CE crossmember. I see their front crossmember has 3 holes while others have 5. Could I get away with 3? When I mount it, do I want to mount it so the middles hole is level with the ground at ride height?
I was planning on using either QA1 single adjustable or Alston Varishock single adjustables for coil overs. The car won't be purely a race car so I don't need the double adjustables. At this point, I'd rather have the car on the ground and driveable.
Thanks for the pics Al. Did the upper coil over crossmember go through the floor, or were you able to keep the trunk floor pan stock?
Anyone have anymore pics??? It is very much appreciated!!
Re: A body's w/ ladder bars?? [Re: mopowers] #252428
03/14/09 12:44 AM
03/14/09 12:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mount for the shocks was through the trunk. Trunk was not stock at all anyway. Was a flat sheet and bracing. The shocks are fairly short but worked fine. The car went 9.0's with an all motor 511" B1.
Re: A body's w/ ladder bars?? [Re: Al_Alguire] #252429
03/14/09 06:32 AM
03/14/09 06:32 AM
OH.
7074cuda Offline
7074cuda  Offline
OH.
Here's a pic of my 70 Dart with a radical set up.Will it work I will find out.Didn't want to alter floor so I put them forward of axle.If you do this you will have to got to a higher spring rate.Mine are at 125#.Test and tune is all I can do to find correct set up.Traditional is behind axle housing straight up and down.If I need more advice Dave Morgan is a teacher at UNOH and lives less than 10 miles from me.Chassis builders I'm sure will chime in on this.
Re: A body's w/ ladder bars?? [Re: 7074cuda] #252430
03/14/09 07:15 AM
03/14/09 07:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah your spring rate is based on the ratio difference
from the rear to the front of the axle and the percentage
of angle you have the shock at. Also you will need a
stiffer adjustment due to them being forward of the
axle
Re: A body's w/ ladder bars?? [Re: MR_P_BODY] #252431
03/14/09 07:41 AM
03/14/09 07:41 AM
OH.
7074cuda Offline
7074cuda  Offline
OH.
Your on the money Mr P Body.Untill I get it all together,hopefully by June, T & T is all I can do.I wasn't sold on it right away after having 4 link car and my last car was ladder bar that it was kinda of strange.Doesn't hurt to think out of the box.I have a mild 440 setup going in it.
Re: A body's w/ ladder bars?? [Re: 7074cuda] #252432
03/14/09 08:19 AM
03/14/09 08:19 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
My car has an Alston chassis, with the rear coil springs in front of the rear. It works fine.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: A body's w/ ladder bars?? [Re: Dartsport540] #252433
03/14/09 09:13 AM
03/14/09 09:13 AM
OH.
7074cuda Offline
7074cuda  Offline
OH.
Nice ride.I see it hooks rather well.Hopefully mopowers gets a good idea for his suspension.
Re: A body's w/ ladder bars?? [Re: 7074cuda] #252434
03/14/09 10:45 AM
03/14/09 10:45 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for the pictures guys. I have one more question.
Since my car has leafs still, can I put the car up on jack stands and leave the leaf springs on to hold the rear where it goes and just tack all the ladder bar and coil over brackets to the housing? It seems like it would be a lot easier getting everything lined up that way.
And if you couldn't tell, tihs is my first ladder bar install.
Re: A body's w/ ladder bars?? [Re: mopowers] #252435
03/14/09 11:09 AM
03/14/09 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you can do it that way but make sure the pinion
angle is correct with your weight in the seat and
make sure the axle is square in the car. Have the
stand under the axle housing
Re: A body's w/ ladder bars?? [Re: MR_P_BODY] #252436
03/14/09 01:41 PM
03/14/09 01:41 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i put ladder bars and coil overs on my 71 dart. I did just that...left the leaf springs on to keep the rear end in place... i removed the rear shackles that allowed me to raise the rear...or lower the car to set the ride hight..
also made and installed frame connectors out of 2 x3 box tubing...I did not have to cut the floor but i tied the roll bar into the frame connector ..
Tony
70 AARCuda Vitamin C
Re: A body's w/ ladder bars?? [Re: 70AARcuda] #252437
03/14/09 01:49 PM
03/14/09 01:49 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i had to cut a piece out of the rear trunk to get the ride height on the shocks, i latter patched it back in...
also was installing tubs on the car at the same time...Had alot of fun...
you will see why chasis guys charge what they do...LOL
Tony
Re: A body's w/ ladder bars?? [Re: 70AARcuda] #252438
03/14/09 01:50 PM
03/14/09 01:50 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
another photo..
Tony
Re: A body's w/ ladder bars?? [Re: 70AARcuda] #252439
03/15/09 12:12 PM
03/15/09 12:12 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
70AARcuda,
I've got a question for you. How did you attach your safety tabs to your CA chassis works ladder bars? i just installed their ladder bars on my car, but i can't find a good way to attach the safety tabs they provide. They look to be in the way no matter how you install them. thanks-Andy
Re: A body's w/ ladder bars?? [Re: MR_P_BODY] #252440
03/15/09 07:56 PM
03/15/09 07:56 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks again for all of the pictures guys. Any more would be greatly appreciated.
Yes you can do it that way but make sure the pinion angle is correct with your weight in the seat and make sure the axle is square in the car. Have the stand under the axle housing
I don't have the perches welded on yet, so pinion angle adjustments will be easy.
Do I have to wait to do the ladder bars until the whole car is built to make sure every ounce of weight is on the car?
Re: A body's w/ ladder bars?? [Re: mopowers] #252441
03/15/09 08:46 PM
03/15/09 08:46 PM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
here are pics of my 65 dart with ladder bars and home made frame connectors. Brad
Re: A body's w/ ladder bars?? [Re: roadrunnerreds] #252442
03/15/09 08:47 PM
03/15/09 08:47 PM
Gettysburg Pa
Gettysburg Pa
pic 2
