Re: Diablo (Truck Pulling) Off to a good start this season*Video
[Re: Diablo]
#2522145
07/15/18 02:52 PM
07/15/18 02:52 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
Pics
[Re: Diablo]
#2522208
07/15/18 04:54 PM
07/15/18 04:54 PM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
Congratulations on the wins! Again, awesome truck.
[Re: camastomcat]
#2522223
07/15/18 05:48 PM
07/15/18 05:48 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Awesome deal my hat's off to you and your team. Love to see the Mopars compete at the highest level
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: moparx]
#2522666
07/16/18 05:15 PM
07/16/18 05:15 PM
WHITEDART
bean town ....Ca
quick question what kind of power is this unit making..
[Re: Diablo]
#2522706
07/16/18 06:42 PM
07/16/18 06:42 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I was just wondering about you last week, hadn't seen you around. Awesome start to the season, keep up the good work in a sea of Ferds and Chebies. Or is that a sea a Ferds with Chevies. What I want to know though is what you use for a transmission and what gears you use in that trans for a pull.
[Re: WHITEDART]
#2522731
07/16/18 07:07 PM
07/16/18 07:07 PM
Diablo
Quebec, Canada
quick question what kind of power is this unit making.. This engine makes 1600++hp at 8300 and 1125 torque at 7300. It is on par if not stronger then the best Sonny 650ci engines for Truck Pulling.
[Re: Guitar Jones]
#2522736
07/16/18 07:12 PM
07/16/18 07:12 PM
Diablo
Quebec, Canada
I was just wondering about you last week, hadn't seen you around. Awesome start to the season, keep up the good work in a sea of Ferds and Chebies. Or is that a sea a Ferds with Chevies. What I want to know though is what you use for a transmission and what gears you use in that trans for a pull. For us we use a Modified Powerglide Tranny. Set up to run only in direct. We have a Quick change transfer case that we do all our ratio changes. Takes about 5 min to change to just about what ever final drive we want for the track we are at. With the tranny running in high there isn't a big chunk of stress there. Most of it is in the rear ends which are 7:20 in the rear and 6:80 in the front. In the rear we run a SQHD which is pretty much what you have in the back on a Semi. The 2 1/2 ton Rockwell stuff doesn't seem to live long after the 1400hp mark on good tracks. Others use a Centrifugal Clutch set up, with a reverser off the transfer case. .
[Re: HardcoreB]
#2523011
07/17/18 11:27 AM
07/17/18 11:27 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Maybe it's just me but I feel a better name for this thread title should be "Why everyone needs a 650 Goodwin Hemi" Long live N/A! ....that mill sounds incredible!
