trans brake button placement? #252210
03/13/09 02:02 AM
03/13/09 02:02 AM
Port Mcneill,B.C.Canada
I
Islandcuda Offline OP
I
Hi guys, , I was going to place my trans brake button on my steering wheel but one issue is the spokes aren,t where I usually place my hand, I could learn to hold my hand alsewhere on the wheel, or replace the wheel. The other thought is behind my shifter, as I built a stand for it and it would be comfortable there. So I,m thinking hold the button floor it , let go reach up and shift. I have the biondo button .o3 delay so the button is quite long. What are your thoughts as I,ve never used a trans brake before, thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: trans brake button placement? [Re: Islandcuda] #252211
03/13/09 02:06 AM
03/13/09 02:06 AM
Cab_Burge Online work
Cab_Burge  Online Work
Put it where you are comfortable with it and make sure it is safe
Re: trans brake button placement? [Re: Cab_Burge] #252212
03/13/09 02:13 AM
03/13/09 02:13 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I agree with cab. sit in your car and try to find the most comfortable place. I like mine down by the shifter in my dads duster but in my cuda i like it on the steering wheel.
I've always let go of the button the reached up to shift 2nd. It's a natural motion.
Re: trans brake button placement? [Re: ChrisJohnston669] #252213
03/13/09 03:28 AM
03/13/09 03:28 AM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
Mine is on the roll cage above me. I have one set up for left hand and one for the right hand depending who is driving.
Why does divorce cost so much? Because it is worth it!!!!!
Re: trans brake button placement? [Re: mopar376d] #252214
03/13/09 08:58 AM
03/13/09 08:58 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
It's a matter of personal preference. My dad, and youngest brother like thiers on the wheel. Mine MUST be down by the shifter, I've never been able to cut a light with buttons on the wheel, it's really a noticeable difference in my case.
My Challenger has a funny car cage, and you sit low, so the button mount ended up on the passengers side of the tunnel, even with the shifter.
In my Valiant, the seat is off the floor, so I took the two large bolts that run through the top portion of a Cheetah SCS Shifter, attached a flat bar running back from those about 4 inches behind the shifter, and mounted the button to that. To just look in the 2 cars, it appears to be 2 completely different locations, but I can drop my arm down without looking, and immediately find them, as the location relative to where I'm sitting is identical.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: trans brake button placement? [Re: Islandcuda] #252215
03/13/09 09:24 AM
03/13/09 09:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It really helps to have it where your comfortable,
I have the same button on my steering wheel on the
left side. Its recessed on a bracket so its not in
the way. I rest my left arm on the door ledge with my
hand on the wheel, thumb on the button.. nice and steady,
works for me
Re: trans brake button placement? [Re: MR_P_BODY] #252216
03/13/09 10:43 AM
03/13/09 10:43 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Mine is located on the shifter as well. I know there are thousands of cars with them on the wheel, but I'm just not comfortable with the wiring gettting wrapped around the column as you turn the wheel. Seems like an opportunity for failure. Maybe that's just me though......
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: trans brake button placement? [Re: nhramark] #252217
03/13/09 11:08 AM
03/13/09 11:08 AM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
I agree with you Mark. I installed mine on the wheel a few years ago. I liked it until I was going into the final and I had to pull out from behind another car. As I was turning the wheel to pull around the cord got hung up and ultimately the wires all got ripped out of the t-brake switch. Now I have it mounted on the dash. I like it! Especially when I have to back up. I love watching my buddies with it on the wheel trying to manouver in the pits. Now I still have the factory steering column in mine so there is lots of places for the cord to get hung up. However, the same thing happened to my buddy in the final of a divisional and he has a tube car with the aftermarket thin column.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: trans brake button placement? [Re: 451Guy] #252218
03/13/09 11:14 AM
03/13/09 11:14 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I have been a floor/shifter mount guy forever. However in the Barracuda the I could not find a comfortable place to mount it on the floor or near the shifter. The F/C cage was an issue with my arm length and size. Like Billy I had never been able to cut alight with one on the wheel but I have concurred that and am now comfortable with it there. But I really would prefer the floor. Or one of those Trans Trigger deals....
Re: trans brake button placement? [Re: Al_Alguire] #252219
03/13/09 12:06 PM
03/13/09 12:06 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
I have mine mounted on the steering wheel and just installed a plug similar to the distributor plug for whenever I am turning.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: trans brake button placement? [Re: juicedcuda] #252220
03/13/09 12:21 PM
03/13/09 12:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a plug also, I use a 1/4" head phone style plug
that plugs into the dash forward of the wheel just above
the steering column. On the switch end it has a couple
of tie wraps that take any load if you were to pull
on the wire... plus I use the coiled type of wire
that you can stretch out
Re: trans brake button placement? [Re: juicedcuda] #252221
03/13/09 12:23 PM
03/13/09 12:23 PM
I
I
Very good suggestions guys, I think the most comfortable position is where it will go. My shifter tower is home built, the right hieght and lots of room, I think I got it. Thanks Tim
Re: trans brake button placement? [Re: juicedcuda] #252222
03/13/09 12:24 PM
03/13/09 12:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have a factory column W/ a removable wheel and wasn't to thrilled about the idea of the cable getting wrapped up. However, after sitting in the car and trying various places and how my arm would "feel" coming off the button the choice for me was clear. On the wheel. So I have to deal with the cord.
It's all about comfort and feel. Put it where it's most natural for you.
And, if you do choose the wheel, and if you need an button to back up (some T brakes do others don't) you can always install a second button that's in a location that's eayier to manuver with.
Re: trans brake button placement? [Re: WILD BILL] #252223
03/13/09 12:37 PM
03/13/09 12:37 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Mine is down behind the shifter.
Re: trans brake button placement? [Re: Islandcuda] #252224
03/13/09 12:39 PM
03/13/09 12:39 PM
Lehigh Acres, Florida
rickstershemi Offline
Wherever you end up mounting it I would make sure you are using arm movement as opposed to just a finger or thumb movement as arm movement is proven to be faster than finger or thumb movement alone. Large muscle groups move faster than small muscle groups. It is also said that most individuals have a faster reaction time using the left arm even if right handed due to the path of nerves from the brain to the arm on your left side is a shorter path. I use my right arm....????
Frank Hawley has some very interesting theories and facts on driver mindset that is pretty cool.
Rickster
Re: trans brake button placement? [Re: Islandcuda] #252225
03/13/09 06:48 PM
03/13/09 06:48 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I have mine on the floor next to the shifter for the delay box and one on the side of the shifter for reverse. Like others have said put it wherever it is most comfortable for you.
Re: trans brake button placement? [Re: PLUM BAD] #252226
03/13/09 07:05 PM
03/13/09 07:05 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I have mine on the dash(knee) bar.It's all personal prefrence
Re: trans brake button placement? [Re: B G Racing] #252227
03/13/09 07:47 PM
03/13/09 07:47 PM
I
I
Being new to trans brake button and reverse pattern shifter I figure go with most comfortable and here it is, thanks, great info, Tim
Re: trans brake button placement? [Re: Islandcuda] #252228
03/13/09 07:52 PM
03/13/09 07:52 PM
I
I
The fun part is going to be figuring out when to let go of the button, and then how much delay I can back out of it or add. I left footbreaking in the middle of the 3rd yellow, but I,m thinking the first sign of 2cnd or3rd yellow would be much better and more consistent not in the middle, Tim
Re: trans brake button placement? [Re: Islandcuda] #252229
03/13/09 08:11 PM
03/13/09 08:11 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
I made a bracket that mounts to the base of my shifer and installed the button off the right side of the shiter.
