How to make my throttle cable work on my 69’ Dart #2521995
07/15/18 12:50 AM
07/15/18 12:50 AM
British Columbia, Canada
3
340Forrest Offline OP
So I have a 69’ Dodge Dart and I just put a 340 stroker motor in it, has a Edelbrock air gap and a Holley 750 4150 on it and my factory cable won’t work, what bracket or cable to I need to change/modify to make it work, it’s the last thing I need to do to make to run, part numbers would be great too if possible!
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2521996
07/15/18 12:53 AM
07/15/18 12:53 AM
AndyF Offline
AndyF  Offline
Mancini Racing has throttle brackets for aftermarket intake manifolds. They also have throttle cables if you need a longer one. They will also have throttle return brackets with dual springs for that engine.
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2521997
07/15/18 12:54 AM
07/15/18 12:54 AM
do you need a longer cable or a taller bracket? (or both)
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2522023
07/15/18 03:29 AM
07/15/18 03:29 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://www.ebay.com/itm/323343221342?ViewItem=&vxp=mtr&item=323343221342
this one includes the throttle return springs and bracket...just got one thursday. shipping cheaper too..
ordered 7-10 received on 7-12...all the way across the country
Tony
70 AARCuda Vitamin C
Re: How to make my throttle cable work on my 69’ Dart [Re: 70AARcuda] #2522038
07/15/18 07:41 AM
07/15/18 07:41 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not a board sponsor
Mancini is a board sponsor
What about your kickdown?? Assuming automatic
http://www.manciniracing.com/retobotokica.html
Bracket, fit's all 4bbl intakes
http://www.manciniracing.com/accamobr.html
Don't be the exception.
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2522124
07/15/18 01:44 PM
07/15/18 01:44 PM
I think you need a six cylinder throttle cable now, especially if your car was a 318 two barrel car to start with shruggy
If your car was a 340 four barrel car the stock cable should still work, what was it originally?
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2522141
07/15/18 02:46 PM
07/15/18 02:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sometimes a little bolt on bracket like this works when going from 2 barrel to 4 barrel. There's 2 of them in this picture.
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2523274
07/17/18 09:46 PM
07/17/18 09:46 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
This is a possibility too. I'm running a 5.9 magnum with an airgap and edelbrock 600cfm. This is in my '68 Dart
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2523462
07/18/18 09:38 AM
07/18/18 09:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I went with the Lokar too, it works great.
Re: How to make my throttle cable work on my 69’ Dart [Re: 340Forrest] #2523475
07/18/18 10:18 AM
07/18/18 10:18 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
