need help i.d.ing these big block heads #252196
03/13/09 01:02 AM
03/13/09 01:02 AM
North Carolina
apairof66s Offline OP
North Carolina
I need help identifying these big block heads.
Here are the numbers.
4006452
33F
*0107*
4006452
27F
*0047*
These have 2.02 intakes.
Thanks in advance for any help.
Lee
Re: need help i.d.ing these big block heads [Re: apairof66s] #252197
03/13/09 01:14 AM
03/13/09 01:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
452's actually they should have 2.08 valves... Standard big block open chamber heads, vintage 72-74ish
Re: need help i.d.ing these big block heads [Re: 1_WILD_RT] #252198
03/13/09 01:18 AM
03/13/09 01:18 AM
North Carolina
North Carolina
Thanks for the quick reply and the info.
Re: need help i.d.ing these big block heads [Re: 1_WILD_RT] #252199
03/13/09 08:02 AM
03/13/09 08:02 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Agreed, but those heads are more like '75-'78. The 346 was used in '72-'73 and there was another one used in '74 (somebody chime in that has more exact info).
The 452 heads are somewhat idolized, flow is reportedly comparable to 906s but the 452 has hardened exhaust seats. Modern alum heads has reduced the furor for them somewhat, though.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: need help i.d.ing these big block heads [Re: Fury Fan] #252200
03/13/09 08:05 AM
03/13/09 08:05 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
By who ???
Re: need help i.d.ing these big block heads [Re: JohnRR] #252201
03/13/09 09:51 AM
03/13/09 09:51 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I don't know about the high-buck racer circle, but 5-10 years ago most of the guys I knew were planning their street builds with the 452s to get the hardened seats. That's all I was saying.
Now the alum heads are on the scene, so times have changed.
Re: need help i.d.ing these big block heads [Re: Fury Fan] #252202
03/13/09 11:15 AM
03/13/09 11:15 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The hardened valve seats in 452's were just induction hardened anyway (I.e. nothing like a hardened valve seat insert), a valve job or two and the hard stuff is gone anyway.
Re: need help i.d.ing these big block heads [Re: ScottSmith_Harms] #252203
03/13/09 11:28 AM
03/13/09 11:28 AM
JohnRR Offline
JohnRR  Offline
yep , and the big thing to do was go to oversize valves , no clue how far out the induction process went or how deep at the 1.81 size ...
just saying ...
Re: need help i.d.ing these big block heads [Re: JohnRR] #252204
03/13/09 01:26 PM
03/13/09 01:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i believe the '452 was 76-78 year engines. 2.08 intake, 1.74 exhaust, about 90cc chambers. inductioned hardened exhaust seat. the induction hardening may vary in depth from .030-.060 deep. i think they're o.k. for a moderate 93 octane street build. going to a larger exhaust valve may be a crap shoot on the induction hardening. some shops that do it say they are putting a new seat on top of the outer portion of the hardening. i did talk to an engineer at a plant that did induction hardening for some ford diesel engines and he said their minimum depth was .030".
Re: need help i.d.ing these big block heads [Re: apairof66s] #252205
03/13/09 09:54 PM
03/13/09 09:54 PM
Oklahoma
gregok Offline
gregok  Offline
Oklahoma
I believe that 452's were available in 1971.
