65 b-body colum shift (cable) to 66 and up torqueflite #2519303
07/08/18 10:28 PM
07/08/18 10:28 PM
USA
SSAAHemiFan Offline OP
USA
putting a bb into a 65 belvedere bench seat with column shift - the trans choice is up in the air.
I do not have a 65 cable shift slip yoke bb trans but have a rebuilt 68 full manual t-flite and new converter on the extra parts shelf.
AA trans lists a conversion kit for 65 column shift to newer torqueflite, not sure if this is the imperial services kit or not but a quick net search shows the imperial services kit has issues.
Does anybody have any experience with these kits to retain the column shift with a newer t-flite?
I know I can install a floor shifter with the newer trans but trying to avoid it.
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: SSAAHemiFan] #2519399
07/09/18 02:22 AM
07/09/18 02:22 AM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
I bought the Imperial Services cable when I went to a newer 727 (sb) in my '65 Belvedere. After a minimal amount of adjustment, I'm very happy with it. One thing I did counter to their instructions was use the later detent ball spring. It's stiffer, making the shifting at the lever feel a little more positive. The only downside was that it took about 6 months for them to ship me the cable kit. Charged my card the day I ordered it, of course.
In order to know what you want, you'll probably have to find out what you don't want.
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: SSAAHemiFan] #2519425
07/09/18 08:38 AM
07/09/18 08:38 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
You may want to do a search on Imperial Services before you order anything from there.
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: TooMany62s] #2519482
07/09/18 01:19 PM
07/09/18 01:19 PM
moparx Offline
moparx  Offline
which is why, when the time comes to adapt a pushbutton setup to whatever transmission i decide on for my 33 humpback project, i will figure this out on my own instead of ordering a kit. if they can do it, someone else [me ?] can with a little effort.
beer
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: SSAAHemiFan] #2519572
07/09/18 03:52 PM
07/09/18 03:52 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I have the same issue. Wanting to put a later trans in my 65 so I can use a gear vendors overdrive.
I've heard that Imperial services works with their distributors better than their direct customers so A&A may be a good source for it. If that is in fact who is making it.............
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: SSAAHemiFan] #2519596
07/09/18 04:31 PM
07/09/18 04:31 PM
Grove, OK
hosehead Offline
hosehead  Offline
Grove, OK
If you use the later trans, a 66 column and linkage works great. No aftermarket parts needed. I did this on my 65 bel 2. Even the column wiring is the same.
63 Plymouth savoy
65 d100
66 dart race project
58 plymouth suburban
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: SSAAHemiFan] #2519663
07/09/18 07:15 PM
07/09/18 07:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
^^^^^ what I was going to do, but then I found a 65 trans. I would think a 66-69 column would work too, maybe even an a-body one.
Also get the speedo cable off the 66, only mopar one that mates up to later trans and 65 and down speedo. A Camaro cable works too.
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: cudaman1969] #2520037
07/10/18 03:56 PM
07/10/18 03:56 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I looked at that option first as well........just my luck, C bodies changed from 65 to 66........
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: SSAAHemiFan] #2520305
07/11/18 12:14 AM
07/11/18 12:14 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I put a column out of a 68 Roadrunner into my old 64 Belvedere wagon, to get rid of the typewriter shifter when I went to a later style BB 727. It was about a bolt in.
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: JDMopar] #2521693
07/14/18 12:58 AM
07/14/18 12:58 AM
USA
USA
thanks all for the info. I am going to see what I come up with at the nats and at least have a chance to talk to the A&A guys.
Can I get a little more info here about using a 1966 mopar or Camaro speedo cable ?
What year Camaro cable is needed and does it require modification ?
thanks
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: SSAAHemiFan] #2521698
07/14/18 01:30 AM
07/14/18 01:30 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
thanks
The '68 Camaro adapts the small speedo head from the early B's to the larger speedo head on the later 727. Length is perfect for an early B and it virtually falls into place.
'63 Dodge 330
11.19 @ 121 mph
Re: 65 b-body colum shift (cable) to 66 and up torqueflite [Re: GY3] #2521850
07/14/18 03:39 PM
07/14/18 03:39 PM
moparx Offline
moparx  Offline
thanks
correct ! this cable fits up to when they went to the white, plastic speedometer end. was that 68 ?
beer
