Re: 65 b-body colum shift (cable) to 66 and up torqueflite
[Re: SSAAHemiFan]
#2519399
07/09/18 02:22 AM
07/09/18 02:22 AM
Posts: 157 Winlock, Wa
fshd4it
Winlock, Wa
I bought the Imperial Services cable when I went to a newer 727 (sb) in my '65 Belvedere. After a minimal amount of adjustment, I'm very happy with it. One thing I did counter to their instructions was use the later detent ball spring. It's stiffer, making the shifting at the lever feel a little more positive. The only downside was that it took about 6 months for them to ship me the cable kit. Charged my card the day I ordered it, of course.
In order to know what you want, you'll probably have to find out what you don't want.
[Re: SSAAHemiFan]
#2519596
07/09/18 04:31 PM
07/09/18 04:31 PM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
If you use the later trans, a 66 column and linkage works great. No aftermarket parts needed. I did this on my 65 bel 2. Even the column wiring is the same.
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
[Re: SSAAHemiFan]
#2519663
07/09/18 07:15 PM
07/09/18 07:15 PM
Posts: 8,271 fredericksburg,va
cudaman1969
fredericksburg,va
^^^^^ what I was going to do, but then I found a 65 trans. I would think a 66-69 column would work too, maybe even an a-body one. Also get the speedo cable off the 66, only mopar one that mates up to later trans and 65 and down speedo. A Camaro cable works too.
[Re: cudaman1969]
#2520037
07/10/18 03:56 PM
07/10/18 03:56 PM
Posts: 1,377 Back In Iowa
belv2vert66
Back In Iowa
^^^^^ what I was going to do, but then I found a 65 trans. I would think a 66-69 column would work too, maybe even an a-body one. Also get the speedo cable off the 66, only mopar one that mates up to later trans and 65 and down speedo. A Camaro cable works too. I looked at that option first as well........just my luck, C bodies changed from 65 to 66........
[Re: SSAAHemiFan]
#2521698
07/14/18 01:30 AM
07/14/18 01:30 AM
Posts: 4,678 Wichita
GY3
Wichita
thanks all for the info. I am going to see what I come up with at the nats and at least have a chance to talk to the A&A guys.
Can I get a little more info here about using a 1966 mopar or Camaro speedo cable ?
What year Camaro cable is needed and does it require modification ?
thanks The '68 Camaro adapts the small speedo head from the early B's to the larger speedo head on the later 727. Length is perfect for an early B and it virtually falls into place.
[Re: GY3]
#2521850
07/14/18 03:39 PM
07/14/18 03:39 PM
Posts: 19,408 north of coder
moparx
thanks The '68 Camaro adapts the small speedo head from the early B's to the larger speedo head on the later 727. Length is perfect for an early B and it virtually falls into place. correct ! this cable fits up to when they went to the white, plastic speedometer end. was that 68 ?
