Page 3 of 4 1 2 3 4
Re: Why everyone needs a turbo [Re: polyspheric] #2521499
07/13/18 03:44 PM
07/13/18 03:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted By polyspheric
theory's from the keyboard jockeys
LOL!
That's me. Never had a wrench in my hand, put anything together, tuned or ran anything but my mouth.
Re: Why everyone needs a turbo [Re: polyspheric] #2521528
07/13/18 05:19 PM
07/13/18 05:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
LOL!
https://youtu.be/aE_lrZEEc94
Yeah, turbos aren't consistent at all...
Go to 27:50 in the video.
'63 Dodge 330
11.19 @ 121 mph
Re: Why everyone needs a turbo [Re: 1980volare] #2521620
07/13/18 09:20 PM
07/13/18 09:20 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I'd explain, but the IQ levels displayed make that sort of... pointless.
Boffin Emeritus
Re: Why everyone needs a turbo [Re: polyspheric] #2521623
07/13/18 09:30 PM
07/13/18 09:30 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Agreed, pointless
Re: Why everyone needs a turbo [Re: polyspheric] #2521643
07/13/18 10:04 PM
07/13/18 10:04 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Nevermind
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Why everyone needs a turbo [Re: polyspheric] #2521660
07/13/18 10:58 PM
07/13/18 10:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yup, pointless is you on a mopar site thinking you are some kind of know it all.
Re: Why everyone needs a turbo [Re: polyspheric] #2521777
07/14/18 12:28 PM
07/14/18 12:28 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
How can you explain? - you have never done anything like it - so it is pointless then!
Re: Why everyone needs a turbo [Re: 1980volare] #2521884
07/14/18 05:14 PM
07/14/18 05:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Sorry, have you made an extensive tour of my property and history? I began work on cars in 1963, were you there? I don't recall.
My DD is a 520 hp twin turbo 2JZ-GTE Lexus. I started working on turbos in 1975 with a Corvair Corsa, then in 1978 with a new Riviera V6.
Remind me: when did I make any claim to "know everything"? Try limiting your insults to facts?
Please enlighten me: exactly which statements of mine are WRONG (as opposed to "things you don't understand")?
You're up.
Boffin Emeritus
Re: Why everyone needs a turbo [Re: 1980volare] #2521898
07/14/18 06:04 PM
07/14/18 06:04 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
where consistency matters anyhow.
Unfortunately true.
In addition to all the other annoying variables (air density, ATF temperature, octane) you have to add intercooler efficiency (what's the actual output temperature?), time to spool, does spark retard kill more power than too rich (for the same degree of anti-knock defense).
When you read that "on a turbo car the tune is worth 500 hp", that's what they're talking about.
Poly you're a smart guy, but man can you come off arrogant sometimes.
First... air density changes effect all cars, not just turbos. My guess is you already know that though.
ATF temp effects all cars... not just turbos. An improperly sized trans cooler on anything is going to suffer repeatability issues.
Explain to me how octane on a turbo car effects repeatability? Any car that doesn't have enough of it N/A or Turbo, is going to detonate and have issues. It's not a "Turbo" thing.
Intercooler efficiency effects power... not consistency. Put a good sized intercooler on it, and you don't have to worry about heat soak. No different then making sure a NA car has the proper sized radiator.
Time to spool is repeatable as hell. It's a mechanical device, there is no magical external unpredictable forces in the world that make it spool fast one time, and slow another. The mass flow from the engine is predictable, and that's what makes the turbo spool. I have HUNDREDS of data logs that prove it.
My boost controller holds the boost within 0.1psi of the targeted curve throughout the run. It will go from 13psi to 20psi in about 0.3sec.
What does spark retard killing more or less power then A/F ratio have to do with bracket racing?
It's like any NA car. You get a good tune in it, and leave it alone when you're bracket racing it. Who would re-jet or move spark around in between rounds at a race?
If we're going to focus on facts...
I have 100's of passes, timeslips, and data logs from a turbo car that I actually bracket race. You're up.
Re: Why everyone needs a turbo [Re: 1980volare] #2521921
07/14/18 08:09 PM
07/14/18 08:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd have to say that there are plenty of good bracket racers that would rather face someone else than Dizuters turbocar. For as seldom as he gets to race it, goes rounds nearly every time out.
Doug
Re: Why everyone needs a turbo [Re: 1980volare] #2521955
07/14/18 10:21 PM
07/14/18 10:21 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Time for a group hug.
You won’t find a stronger proponent for turbos than I, but .... If I were building a bracket car, it would be either N/A and light,(choice #1) or turboed and heavy (choice #2)
A turbo car that is light and at its limits will repeat easier than that same car turned way down to meet an index.
Results may vary... grin
Re: Why everyone needs a turbo [Re: 1980volare] #2522125
07/15/18 01:55 PM
07/15/18 01:55 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Stupid turbos.
I got runner up last night πŸ˜›
I treed him and out 60 foot him with my new best 1.14
He drove around me. I make 20 PSI on gas. His Procharged BBF on alcy makes 38 PSI . He got me by a car.
Re: Why everyone needs a turbo [Re: FastmOp] #2522147
07/15/18 02:57 PM
07/15/18 02:57 PM
fredericksburg,va
fredericksburg,va
Originally Posted By FastmOp
Stupid turbos.
Running heads up? Or couldn't run your dial? I wouldn't bring a knife to a gun fight.
Re: Why everyone needs a turbo [Re: FastmOp] #2522166
07/15/18 03:29 PM
07/15/18 03:29 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Stupid turbos.
Obviously you need more boost! boogie
Re: Why everyone needs a turbo [Re: 1980volare] #2522211
07/15/18 05:01 PM
07/15/18 05:01 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Heads up.
Yep. Need another 10 pounds.
I'm having fun.
Re: Why everyone needs a turbo [Re: polyspheric] #2522460
07/16/18 10:35 AM
07/16/18 10:35 AM
an8sec70cuda Offline
You're up.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Why everyone needs a turbo [Re: 1980volare] #2548998
09/11/18 10:11 PM
09/11/18 10:11 PM
Mo.
racerx Offline
racerx  Offline
Mo.
bump any new news on this?
Re: Why everyone needs a turbo [Re: 1980volare] #2549044
09/11/18 11:35 PM
09/11/18 11:35 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a turbo problem. I like them so much I had to get two for the next Hemi build.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Why everyone needs a turbo [Re: an8sec70cuda] #2549085
09/12/18 01:15 AM
09/12/18 01:15 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
After YEARS of reading Poly's posts both on here and elsewhere, there's no doubt he is a thinker and very knowledgable in this caper.
But seriously....his choice of words on forums are perhaps a little abrasive and can be processed as a form of arrogance.
All of us have knowledge some less than others however projecting oneself as the last word is really unnecessary.
We all want to learn as much as we can....without the aggravation.
Re: Why everyone needs a turbo [Re: 1980volare] #2549087
09/12/18 01:20 AM
09/12/18 01:20 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Yes, it's only helpful if you tell people what they want to hear. Anything else is just sooo hurtful.
Boffin Emeritus
Page 3 of 4 1 2 3 4
