Re: Tach issues need a recommendation
[Re: The Sphinx]
#2521725
07/14/18 08:10 AM
07/14/18 08:10 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
This seems weird but does the engine have a good ground? I killed my autometer tach when I tried to start the car with no ground wire on the engine. Tach pegged when I hit the starter and never worked again.
68 Barracuda Formula S 340
[Re: The Sphinx]
#2522451
07/16/18 10:24 AM
07/16/18 10:24 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I've had the same Autometer Sport Comp 5" monster tach w/ shift light in the cuda for probably 17 years now.
[Re: nss guy]
#2522482
07/16/18 11:35 AM
07/16/18 11:35 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Accutronic here, no problem with wiring Me too, old school mechanical. This photo could be captioned, why you should not be the first to run after a jet car.
[Re: The Sphinx]
#2522744
07/16/18 07:36 PM
07/16/18 07:36 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
I think you need more pinion angle
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
