Tach issues need a recommendation #2521265
07/12/18 11:41 PM
07/12/18 11:41 PM
Champion City
The Sphinx Offline OP
Champion City
My car seems to eat tachs. I usually go cheap as I only use it for staging and shift via stand alone msd shift light. First tach was an eqquis that had a 5 star rating. Lasted 2 years. Next one was a summit cheapo that lasted 1 year. Per the tach my car idles at 0 rpm, needs to go. Is it that im using cheap crap? What do y'all recommend for a replacement?
Re: Tach issues need a recommendation [Re: The Sphinx] #2521287
07/13/18 12:53 AM
07/13/18 12:53 AM
Washington
madscientist Offline
Washington
Autometer and be done.
Re: Tach issues need a recommendation [Re: The Sphinx] #2521295
07/13/18 01:05 AM
07/13/18 01:05 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Two of my AutoMeters celebrated their 35th birthday, and one recently turned 24...all hooked to MSD units.
Re: Tach issues need a recommendation [Re: topside] #2521315
07/13/18 02:16 AM
07/13/18 02:16 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Autometer fan here as well. Would not even look at anything else.
Re: Tach issues need a recommendation [Re: The Sphinx] #2521343
07/13/18 08:22 AM
07/13/18 08:22 AM
Locomotion Offline
Locomotion  Offline
Autometer user here too. I learned long ago that it's better to get good stuff right off the bat. Their playback versions might be worth considering. I learned a LOT because I saw what was actually happening on the replays wasn't always what I thought was happening.
Re: Tach issues need a recommendation [Re: The Sphinx] #2521523
07/13/18 05:07 PM
07/13/18 05:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sweet Jeebis, what the heck has happened ??!!! A consensus on Moparts !!!
(Disclaimer: This reply is what's called playful sarcasm, intended for a laugh only)
Re: Tach issues need a recommendation [Re: The Sphinx] #2521581
07/13/18 07:36 PM
07/13/18 07:36 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Accutronic here, no problem with wiring
Re: Tach issues need a recommendation [Re: The Sphinx] #2521725
07/14/18 08:10 AM
07/14/18 08:10 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
This seems weird but does the engine have a good ground? I killed my autometer tach when I tried to start the car with no ground wire on the engine. Tach pegged when I hit the starter and never worked again.
68 Barracuda Formula S 340
Re: Tach issues need a recommendation [Re: The Sphinx] #2522451
07/16/18 10:24 AM
07/16/18 10:24 AM
an8sec70cuda Offline
I've had the same Autometer Sport Comp 5" monster tach w/ shift light in the cuda for probably 17 years now.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Tach issues need a recommendation [Re: nss guy] #2522482
07/16/18 11:35 AM
07/16/18 11:35 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Me too, old school mechanical. This photo could be captioned, why you should not be the first to run after a jet car.
Re: Tach issues need a recommendation [Re: The Sphinx] #2522744
07/16/18 07:36 PM
07/16/18 07:36 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I think you need more pinion angle
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
