Re: Fluttering in high gear
[Re: Derrick Payne]
#2520897
07/12/18 05:10 AM
07/12/18 05:10 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
I put a big block in my duster that the motor had been setting for a few years and it’s goes to fluttering at higher rpm’s in high gear I was wondering if the value springs would be the problem is this at wide open throttle or part throttle cruising?
[Re: Derrick Payne]
#2521097
07/12/18 04:26 PM
07/12/18 04:26 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Sure sounds like a fuel issue. Do you have a fuel pressure gauge you can see going down the track?
[Re: Derrick Payne]
#2521226
07/12/18 10:10 PM
07/12/18 10:10 PM
Cab_Burge
A sure fire way to test the fuel system for adequate fuel delivery is to jet the carb. up one or two steps at a time until the 1/4 MPH slows down, if you can't do that you don't have enough fuel delivery This is a very common problem on our Mopar production muscle cars with stock fuel pickups in the tank and stock fuel lines from the tank to the front of the car I would set the pressure between 7.5 and 9.5 lbs. with a Holley carb.(not above 7.5 lbs high on a Carter or Eddy carb ) with .110 needles and seats and jet it up until you find out what you need to know IHTHs
