Re: need correct pulley for water pump 426 hemi [Re: CSK] #2519915
07/10/18 11:11 AM
07/10/18 11:11 AM
fresno
hyefatman Offline OP
fresno
Just because it fits (pulleys) does not mean it works. Bouchillon performance (randy) still thinks that you can run 440 (non ac) water pump pulley with stock two grove crank pulley (thin damper) on a street 1970 hemi. I am 100% convinced that the ratio does not allow water movement at idle. I have spent thousands of $$$ with moparts sponsors, but at some point when you sell a product that doesnt work you should stand behind it or at least not sell it anymore for the above application. (that includes 440-source) So I am still looking for a water pump pulley (non a.c big block) with 5.5 diameter that would work for my setup.
Re: need correct pulley for water pump 426 hemi [Re: hyefatman] #2519986
07/10/18 01:54 PM
07/10/18 01:54 PM
moparx Offline
moparx  Offline
as pulley offsets are something you need to take into consideration, perhaps, and this is a REAL stretch, you may be able to look at some GM pulleys, then use thin spacers to align the belts ? just throwing something out there. i have seen a ton of SBC pulleys with duel bolt patterns, but watch the center hole size, as there are several, ranging from 5/8" to 3/4" or larger.
beer
Re: need correct pulley for water pump 426 hemi [Re: hyefatman] #2520138
07/10/18 07:13 PM
07/10/18 07:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I linked you to a 5.5" pulley.
That is the size you say you need.
What are you waiting for?
Don't be the exception.
Re: need correct pulley for water pump 426 hemi [Re: Supercuda] #2520247
07/10/18 10:17 PM
07/10/18 10:17 PM
Supercuda the man thanked you for the info. He is waiting on me to see what I have/how much (tomorrow likely).
Re: need correct pulley for water pump 426 hemi [Re: RapidRobert] #2520342
07/11/18 01:24 AM
07/11/18 01:24 AM
fresno
fresno
The pulley that was linked is a a/c pulley and I donot think it will work with a 2 grove crank pulley. If I go with that pulley I will have to add a 4 grove crank pulley.
Re: need correct pulley for water pump 426 hemi [Re: hyefatman] #2520445
07/11/18 11:53 AM
07/11/18 11:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is correct. But if you can find an A/c pulley and the 4 groove lower pulley for cheap it would be a good way to test out your theory before dropping the big coin on $HEMI$ specific parts ??? ...
Re: need correct pulley for water pump 426 hemi [Re: JohnRR] #2520703
07/11/18 07:32 PM
07/11/18 07:32 PM
6&3/8-2&3/16 (2) groove. 6&7/16-1&7/8 (1) groove. 5&7/8-2&3/16 (1) groove. 6&15/16-3 (1) groove. 6&3/8-2&5/8 (2) groove. 6&1/2-2&11/16 (2) groove. 5&1/2 and 6&3/16, this is a (2) groove (2) different diameters with 2&5/8 total height. 6&1/2-2&11/16 (1) groove. WP pulleys
Re: need correct pulley for water pump 426 hemi [Re: RapidRobert] #2520895
07/12/18 05:05 AM
07/12/18 05:05 AM
fresno
fresno
Thanks for the help. I was able to find an a/c big block water pump pulley two grove that I added with a 4 grove crank pulley. I rerouted the belts and problem fixed. It did not go a hair over 180. Lesson learned. Hopefully, this posts helps others in the future. Thanks.
Re: need correct pulley for water pump 426 hemi [Re: hyefatman] #2520943
07/12/18 10:44 AM
07/12/18 10:44 AM
what diameters did you end up with (crank/wp)?
Re: need correct pulley for water pump 426 hemi [Re: hyefatman] #2520972
07/12/18 12:16 PM
07/12/18 12:16 PM
fresno
fresno
The trick was the four grove crank pulley which is bigger dia 7inch combined with a 2 groove stock a/c pulley O.D. 5 7/8. I think part of my problem is the 440 source Double Groove Crank Pulley is 1/2 inch smaller in the inner grove than the stock pulley. I guess that 1/2 inch difference made a 10-15 percent difference in rpm rotation.
Re: need correct pulley for water pump 426 hemi [Re: hyefatman] #2521003
07/12/18 01:22 PM
07/12/18 01:22 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have used all stock 440 pulleys & water pumps on my hemi's on the street with no issues in the past. With everything you have changed/replaced & still having issue I am thinking it may be an intake leak/vacuum leak making it run lean or timing issues possibly?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: need correct pulley for water pump 426 hemi [Re: 6PKRTSE] #2521067
07/12/18 03:31 PM
07/12/18 03:31 PM
fresno
fresno
Are you running single or double grove water pump pulley? Are the repro units from 440 source ?
