Re: need correct pulley for water pump 426 hemi
[Re: hyefatman]
#2520138
07/10/18 07:13 PM
07/10/18 07:13 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
So I am still looking for a water pump pulley (non a.c big block) with 5.5 diameter that would work for my setup. I linked you to a 5.5" pulley. That is the size you say you need. What are you waiting for?
[Re: Supercuda]
#2520247
07/10/18 10:17 PM
07/10/18 10:17 PM
RapidRobert
Supercuda the man thanked you for the info. He is waiting on me to see what I have/how much (tomorrow likely).
[Re: hyefatman]
#2520445
07/11/18 11:53 AM
07/11/18 11:53 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
The pulley that was linked is a a/c pulley and I donot think it will work with a 2 grove crank pulley. If I go with that pulley I will have to add a 4 grove crank pulley. That is correct. But if you can find an A/c pulley and the 4 groove lower pulley for cheap it would be a good way to test out your theory before dropping the big coin on $HEMI$ specific parts ??? ...
[Re: JohnRR]
#2520703
07/11/18 07:32 PM
07/11/18 07:32 PM
RapidRobert
6&3/8-2&3/16 (2) groove. 6&7/16-1&7/8 (1) groove. 5&7/8-2&3/16 (1) groove. 6&15/16-3 (1) groove. 6&3/8-2&5/8 (2) groove. 6&1/2-2&11/16 (2) groove. 5&1/2 and 6&3/16, this is a (2) groove (2) different diameters with 2&5/8 total height. 6&1/2-2&11/16 (1) groove. WP pulleys
[Re: hyefatman]
#2520943
07/12/18 10:44 AM
07/12/18 10:44 AM
RapidRobert
what diameters did you end up with (crank/wp)?
[Re: hyefatman]
#2521003
07/12/18 01:22 PM
07/12/18 01:22 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I have used all stock 440 pulleys & water pumps on my hemi's on the street with no issues in the past. With everything you have changed/replaced & still having issue I am thinking it may be an intake leak/vacuum leak making it run lean or timing issues possibly?
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
