Re: 69 charger oil sender
[Re: racerlall]
#2520774
07/11/18 10:43 PM
07/11/18 10:43 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Obvious questions. Is the connector on the sender wire clean and free of rust and oxidation? Does it clip firmly to the sender? If the wire is jiggled while the car is running does the gauge move at all?
Scott
1969 Super Bee, 383/4 speed
[Re: racerlall]
#2520880
07/12/18 03:16 AM
07/12/18 03:16 AM
Posts: 82 Oly Wash
racerlall
Oly Wash
new wiring hares clip tight gauge twitches a little on sender but sweeps fine wean grounded
[Re: racerlall]
#2520939
07/12/18 10:38 AM
07/12/18 10:38 AM
StukaJU87
Northern NJ
Was the mechanical gauge screwed into the same spot as the sender when you tried it?
Scott
