69 charger oil sender #2520306
07/11/18 12:21 AM
07/11/18 12:21 AM
Oly Wash
racerlall Offline OP
Oly Wash
so working on this 69 charger and the oil gage is not working the gage bench test good wiring test OK swapped senders still no good should the sender have conductivity between the the plug on top and ground at 0 oil presser
Re: 69 charger oil sender [Re: racerlall] #2520313
07/11/18 12:28 AM
07/11/18 12:28 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No. Have you tried a mechanical gauge to make sure you have oil pressure?
Re: 69 charger oil sender [Re: racerlall] #2520319
07/11/18 12:44 AM
07/11/18 12:44 AM
Oly Wash
Oly Wash
yes
Re: 69 charger oil sender [Re: racerlall] #2520351
07/11/18 01:52 AM
07/11/18 01:52 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you are using thread sealer or tape on the sender it won't work because it uses the block as a ground. If you ground the sender wire and turn the key on does the gauge rise? Testing it that way tells you the gauge is good but don't let it peg the gauge or you can burn it out.
Re: 69 charger oil sender [Re: racerlall] #2520744
07/11/18 09:35 PM
07/11/18 09:35 PM
Oly Wash
Oly Wash
no thread sealant used and gauge test good by grounding the wire
Re: 69 charger oil sender [Re: racerlall] #2520774
07/11/18 10:43 PM
07/11/18 10:43 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Obvious questions. Is the connector on the sender wire clean and free of rust and oxidation? Does it clip firmly to the sender? If the wire is jiggled while the car is running does the gauge move at all?
Scott
1969 Super Bee, 383/4 speed
Re: 69 charger oil sender [Re: racerlall] #2520880
07/12/18 03:16 AM
07/12/18 03:16 AM
Oly Wash
Oly Wash
new wiring hares clip tight gauge twitches a little on sender but sweeps fine wean grounded
Re: 69 charger oil sender [Re: racerlall] #2520939
07/12/18 10:38 AM
07/12/18 10:38 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Was the mechanical gauge screwed into the same spot as the sender when you tried it?
Scott
Re: 69 charger oil sender [Re: racerlall] #2521294
07/13/18 01:03 AM
07/13/18 01:03 AM
Oly Wash
Oly Wash
yes 80 + psi
Re: 69 charger oil sender [Re: racerlall] #2521304
07/13/18 01:21 AM
07/13/18 01:21 AM
Oly Wash
Oly Wash
Im thinking the gauges 2 are both bad looked at the hemi charger in the shop and the needle does not swing as far left wean car is off if you put 9v to just the gauge it will twitch a couple times then swings right it dose the same thing wean in the car and you ground the sending wire so im thinking that they only work with full voltage
Re: 69 charger oil sender [Re: racerlall] #2521308
07/13/18 01:37 AM
07/13/18 01:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Full voltage at the gauge is only about 5v. The regulator on the back of the gauge cluster works like a turn signal flasher turning on and off to supply a 5v supply from a 12v source.
