headers that fit? #2519893
07/10/18 10:29 AM
07/10/18 10:29 AM
ny
marcjames Offline OP
ny
stock 1967 gtx 440 any input would be helpful thank you
Re: headers that fit? [Re: marcjames] #2519899
07/10/18 10:38 AM
07/10/18 10:38 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have no experience with that combination, but TTI seems to have the best reputation for fit. That is providing you follow their installation instructions to the letter.
Good Luck!
Re: headers that fit? [Re: marcjames] #2519908
07/10/18 10:56 AM
07/10/18 10:56 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
tti.
Re: headers that fit? [Re: marcjames] #2519927
07/10/18 11:33 AM
07/10/18 11:33 AM
Germany
rubberduck Offline
rubberduck  Offline
Germany
Doug´s Headers.
Re: headers that fit? [Re: marcjames] #2519943
07/10/18 11:56 AM
07/10/18 11:56 AM
fresno
hyefatman Offline
hyefatman  Offline
fresno
Get the stock hp exhaust and run it all the way back. Zero heat problems, zero clearance problems. Stress free living.
Re: headers that fit? [Re: marcjames] #2519971
07/10/18 01:17 PM
07/10/18 01:17 PM
AndyF Offline
AndyF  Offline
I've never found any headers that fit perfectly but I can't say I've tried every single one on the market either. My suggestion is to use the smallest header size since that increases the odds of it working. A stock big block doesn't need much more than a 1 3/4 header so that should free up some space. Maybe look at the Schumacher tri-y header since they don't take up a ton of space. Good luck.
Re: headers that fit? [Re: AndyF] #2519983
07/10/18 01:48 PM
07/10/18 01:48 PM
moparx Offline
moparx  Offline
schumacher, in many past years, has had a display engine at carlisle with those headers installed. if the OP is going, or knows someone that is, you might consider taking a couple of pics of this setup.
beer
Re: headers that fit? [Re: marcjames] #2520036
07/10/18 03:52 PM
07/10/18 03:52 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Hookers fit pretty decent in a 67 with a 440. I run 5209 (2 inch).
Re: headers that fit? [Re: marcjames] #2520040
07/10/18 04:01 PM
07/10/18 04:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In my 68 satellite with RB motor I’ve run 1-3/4 Eagle(from the 80’s), and Hooker 2” super comp.
I had some SR heads on a RB motor in the car, and installed the TTi 2-2 1/8” step headers for the Indy heads. They were the easiest of the 3 to install.
On my 383 B engine I ran Hooker Competition headers , which are 1-7/8”.
In my car, the Eagles and Hooker Comps were actually harder to get into the car than the big headers, but once installed I felt all four sets fit pretty well.
If you have angle plug heads, the TTi’s generally have the best plug clearance.
Re: headers that fit? [Re: marcjames] #2520046
07/10/18 04:09 PM
07/10/18 04:09 PM
an8sec70cuda Offline
TTI!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: headers that fit? [Re: marcjames] #2520055
07/10/18 04:22 PM
07/10/18 04:22 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have 2" tti headers and a full 3" tti exhaust in my 65 coronet. fit is perfect! 1 3/4" tti's would be very easy and their 1 3/4" shorties are probably easier. I have tti full exhaust with cast manifolds in my 69 coronet r/t, perfect fit.
Re: headers that fit? [Re: markz528] #2520183
07/10/18 08:23 PM
07/10/18 08:23 PM
I have the same Hooker headers on my 1966 Dodge Coronet Deluxe two door sedan with a stock iron headed (452 heads) 440 motor and those headers fit well and weren't hard to install with the new motor, it was a slant six three speed stick car before so I swapped the K member out to a 1968 B Body V8 K member into it also up
Re: headers that fit? [Re: marcjames] #2520245
07/10/18 10:11 PM
07/10/18 10:11 PM
jersey
Spaceman Spiff Offline
jersey
anything other then Cyclone or blackjack.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: headers that fit? [Re: marcjames] #2520278
07/10/18 11:23 PM
07/10/18 11:23 PM
Minn
SportF Offline
SportF  Offline
Minn
TTI headers fit, and they always did. Here is another factor seldom mentioned, their quality is way above everybody else. They will last.
One other factor, they sponsor a number of Nostalgia Super Stock races and groups including Victory Nostalgia Super Stocks. Is there any other header maker sponsoring anybody?
Re: headers that fit? [Re: marcjames] #2520282
07/10/18 11:34 PM
07/10/18 11:34 PM
tucson az
frank Offline
frank  Offline
tucson az
I have 1 7/8 TTI in my 69 GTX with RB engine and they fit nice. I installed them with the car on jack stands in my garage without any issues. Stock type steering box but mini starter.
Re: headers that fit? [Re: marcjames] #2520286
07/10/18 11:41 PM
07/10/18 11:41 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Doug's D452 2" primary. Fit great easy install on my 68 B body w/440 with edelbrock heads. Schumachers are 1 5/8" primary. I have them on my 67 Dart w/440 and they fit real easy.
Re: headers that fit? [Re: hyefatman] #2520320
07/11/18 12:47 AM
07/11/18 12:47 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
B O R I N G .
Re: headers that fit? [Re: marcjames] #2520327
07/11/18 01:01 AM
07/11/18 01:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
But still easier to work around when necessary.
Re: headers that fit? [Re: moparx] #2520336
07/11/18 01:19 AM
07/11/18 01:19 AM
KY
65pacecar Offline
65pacecar  Offline
KY
beer
I have a set of Schumacher Tri-Y's on my 65 Sport Fury Big Block and love them. Excellent quality, easy install (from the top), no leaks and the coating is holding up great after 8 years. I will be buying another set. Also had good luck with TTI
Re: headers that fit? [Re: marcjames] #2520375
07/11/18 05:13 AM
07/11/18 05:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
TTI have been the best fitting and working headers I have ever used. They have good plug clearance even with my angle plug EZ heads and IMO are much easier to change the plugs then it would be with exh manifolds. Ron
