5.9 roller Cam Engine PRE MAGNUM #2518340
07/06/18 11:22 AM
07/06/18 11:22 AM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
I started out to find out which engine's I could get a set of the 302 casting number cylinder heads.Since I have been doing research I am asking my self why not a ROLLER 360?Good heads roller cam.WHY NOT?
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: Crabra] #2518351
07/06/18 12:01 PM
07/06/18 12:01 PM
gregsdart Offline
gregsdart  Offline
That would get you close to the best of all worlds for a low cost street build. I would think the block should show minimal wear, being fuel injected.
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: gregsdart] #2518352
07/06/18 12:04 PM
07/06/18 12:04 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
I found one with 91.000 miles on it for 275.00. up
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: Crabra] #2518435
07/06/18 03:05 PM
07/06/18 03:05 PM
dogdays Offline
dogdays  Offline
The roller LA 360 engines came with 308 heads, which were standard Mopar open chamber but with a better exhaust port. They were quickly discovered by the two dozen or so Mopar dirt track racers as the best LA stock head. [No, the W2 is not a stock head.] The heads' exhaust ports were good enough that power was lost using a dual pattern camshaft.
R.
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: Crabra] #2518594
07/06/18 10:04 PM
07/06/18 10:04 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Go for it! Excellent move and well priced. EZ re-use of the OE lifters.
Just ask the cam company if there cam is compatible with the iron gear. This way, you’ll know before hand if you should get the gear upgrade. Save time!
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: Crabra] #2518613
07/06/18 10:53 PM
07/06/18 10:53 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
What years were these? 88-92?
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: slantzilla] #2518648
07/07/18 12:55 AM
07/07/18 12:55 AM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
I think as 88 to 92 but there is some overlap
I had a 91 dakota with a 5.2 magnum
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: Crabra] #2518650
07/07/18 12:59 AM
07/07/18 12:59 AM
CA
crackedback Offline
crackedback  Offline
CA
Chances are likely pretty good that one or both of the heads have cracks.
Great block to start with if you want to run a hyd roller IMO.
Re: 5.9 roller Cam Engine PRE MAGNUM [Re: crackedback] #2518716
07/07/18 09:30 AM
07/07/18 09:30 AM
gregsdart Offline
gregsdart  Offline
[quote=crackedback]Chances are likely pretty good that one or both of the heads have cracks.
[/quote i understand that magnum heads are most likely cracked, but these would be pre magnum,,,,
