Re: 5.9 roller Cam Engine PRE MAGNUM
[Re: Crabra]
#2518594
07/06/18 10:04 PM
07/06/18 10:04 PM
Posts: 792 Earth
Rob C
Earth
I started out to find out which engine's I could get a set of the 302 casting number cylinder heads.Since I have been doing research I am asking my self why not a ROLLER 360?Good heads roller cam.WHY NOT? Go for it! Excellent move and well priced. EZ re-use of the OE lifters. Just ask the cam company if there cam is compatible with the iron gear. This way, you’ll know before hand if you should get the gear upgrade. Save time!
[Re: Crabra]
#2518613
07/06/18 10:53 PM
07/06/18 10:53 PM
Posts: 20,209 Park Forest, IL
slantzilla
Park Forest, IL
What years were these? 88-92?
[Re: crackedback]
#2518716
07/07/18 09:30 AM
07/07/18 09:30 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
[quote=crackedback]Chances are likely pretty good that one or both of the heads have cracks.
Great block to start with if you want to run a hyd roller IMO. [/quote i understand that magnum heads are most likely cracked, but these would be pre magnum,,,,
