Page 1 of 3 1 2 3
Toatal Seal Gapless rings, fact or fiction? #2517699
07/04/18 10:08 PM
07/04/18 10:08 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
In anticipation of tear down to reduce oil consumption, I have been researching rings. The Total Seal web site would have me using nothing but their gapless rings. What do you engine builders think?
My block is an early Mopar Performance siameased bore.
Thanks for your experience.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517746
07/04/18 11:24 PM
07/04/18 11:24 PM
Washington
madscientist Offline
Washington
I used many sets. Evidently, some people say they have oil control issues with them. I've never seen that.
If you have an oil burner, it's usually not the rings fault.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517761
07/04/18 11:50 PM
07/04/18 11:50 PM
Washington
skrews Online content
skrews  Online Content
Washington
Not worth the money.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517765
07/05/18 12:11 AM
07/05/18 12:11 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Not a fan
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517773
07/05/18 12:39 AM
07/05/18 12:39 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I use the gapless top ring with a napier 2nd ring and a low tension oil ring, my experiance and research this is about the best ring combo you can install in an engine. I would never run a gapless second ring, had bad results doin that. It unseats the top ring under hard acceleration.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517776
07/05/18 01:03 AM
07/05/18 01:03 AM
crabman173
crabman173
Gapless rings were invented to go in dirt track engines so after 3 races they would still have some compression and put off the re-build by a couple weeks--They make a leak down test look Perfect! That part of the advertisement is 100% true--On the dyno they will not make 1 mor HP in the engines I have done--I used to do the circle track 345-360 HP two barrel limited engines Gapless rings were tested again and again--they NEVER made one more HP They leak checked like amazing though
Have true round no taper cylinder bores by using a TQ plate and many other details --use the cheapest rings on the planet and you will have good ring seal use good rings and it can be less resistance and more HP
I do use gapless second rings in my alky / nitro dragster engine because they do keep oil contamination on that fuel eater ( runs gallons through in seconds) to a minimum but they DO NOT make more power or are any better than conventional ring packs on a drag engine for any other reason
This is from observation not reading about it
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517801
07/05/18 03:33 AM
07/05/18 03:33 AM
On your deal I would use a standard tension oil ring set with a good moly top ring and a good second ring gapped about .002 bigger than the recommended minimums up
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Cab_Burge] #2517814
07/05/18 07:33 AM
07/05/18 07:33 AM
Tennessee
Tennessee
Thanks for the replies. Very interesting responses.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517827
07/05/18 08:35 AM
07/05/18 08:35 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I used gapless total seal rings when they first came out. The 340 used a quart of oil every 500 miles. A circle track guy told me to use them! Removed them and fixed the oil consumption. Do what Cab says.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517833
07/05/18 09:01 AM
07/05/18 09:01 AM
The Great White North
RAMM Offline
RAMM  Offline
Gapless--lol. Complete scam. Have used them a few times-all had oil consumption issues. Never use them or recommend them again. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2517983
07/05/18 02:57 PM
07/05/18 02:57 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Well, I used C&A "gapless" 2nd rings two builds ago (similar to the original Total Seal "gapless 2nd), and Total Seal "gapless" top rings w/ traditional 2nd ring and standard-tension oil rings on the build after that. I can't quantify any benefits from either approach, to be blunt.
With my latest (re)build, I returned to conventional top rings and Napier 2nd rings gapped at .020" & .024" respectively. I also went with slightly lighter-tension oil rings (18# vs 21#), but will be keeping an eye on potential oil consumption issues.
"In theory", I like the "gapless" top ring... but you really pay a premium for them. I'd have to see more independent testing from sources I can put 100% faith in before I'd consider trying them again. Since I haven't, my backup short-block parts collection already includes the same ring pack as what I just put into my latest build.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: Hemi ragtop] #2518122
07/05/18 08:00 PM
07/05/18 08:00 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
I use gapless rings to my advantage. Because they leak so little, they allow me to use a sealed pcv system to draw a vacuum in the crankcase, which in-turn allows me to get away with 12lb oil rings to pick up a little power/mileage. My setup draws 15"Hg crankcase down the hiway, without help from a vacuum pump. I do have an electric pump for backup when I spray, but it's not needed even for the occasional WOT NA blast on a backroad.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: weedburner] #2518157
07/05/18 09:14 PM
07/05/18 09:14 PM
Washington
Washington
Don't you know...gapless top rings don't deal. They are all oil burners. That means they are junk.
Now that we dispensed with that, I've use probably a hundred sets of gapless top rings. In everything from street cars, to street/strip junk, bracket engines and some heads up stuff.
Not one of them has ever had a oil using issue. Not one. The shop I was at when we tested them still uses them. Every day. He still has had an oil user come back.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: madscientist] #2518197
07/05/18 10:43 PM
07/05/18 10:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use the Mahle pistons with 1.5, 1.5, 3.0mm file-fit rings and my engine never burns a drop of oil between changes.
I've blown it apart twice since the initial build: once for a bad cam and another for a bearing issue (my fault). Honed it, slammed it back together and zero issues. Set top and 2nd ring gap initially at .024.
'63 Dodge 330
11.19 @ 121 mph
Re: Toatal Seal Gapless rings, fact or fiction? [Re: madscientist] #2518223
07/05/18 11:36 PM
07/05/18 11:36 PM
BradH Offline
BradH  Offline
What cylinder finish has been successful with the TS "gapless" top rings?
Re: Toatal Seal Gapless rings, fact or fiction? [Re: BradH] #2518295
07/06/18 08:12 AM
07/06/18 08:12 AM
Tennessee
Tennessee
So how do you like the Napier 2d ring? I read that they are good for oil control.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: BradH] #2518296
07/06/18 08:17 AM
07/06/18 08:17 AM
Tennessee
Tennessee
I am interested in that also. There IS some recommendations on the TS website. It makes sense because it changes with different hardness of different block/liner.
Re: Toatal Seal Gapless rings, fact or fiction? [Re: GY3] #2518299
07/06/18 08:51 AM
07/06/18 08:51 AM
RAMM Offline
RAMM  Offline
^^^^^^The rings that come in their PowerPak piston sets are excellent. They have now gone with a 1.0/1.0/2.0mm ring pack across their lineup and those work excellent as well. J.Rob
Re: Toatal Seal Gapless rings, fact or fiction? [Re: BradH] #2518303
07/06/18 08:55 AM
07/06/18 08:55 AM
RAMM Offline
RAMM  Offline
If a cylinder finish exists , I haven't found it. I have spent some time on the phone with Keith Jones and have followed his recommendations to a tee even down to the break in oils to stay away from, since he wouldn't outright say which oil to use. J.Rob
Re: Toatal Seal Gapless rings, fact or fiction? [Re: madscientist] #2518305
07/06/18 09:02 AM
07/06/18 09:02 AM
RAMM Offline
RAMM  Offline
I would think if the benefits such as increased mileage/power/emissions even in a minute amount existed with just a gapless ring design, you would find them in every OEM application around the globe. J.Rob
Page 1 of 3 1 2 3
