Re: Toatal Seal Gapless rings, fact or fiction?
[Re: Hemi ragtop]
#2517746
07/04/18 11:24 PM
07/04/18 11:24 PM
Posts: 4,457 Washington
madscientist
Washington
I used many sets. Evidently, some people say they have oil control issues with them. I've never seen that.
If you have an oil burner, it's usually not the rings fault.
[Re: Hemi ragtop]
#2517776
07/05/18 01:03 AM
07/05/18 01:03 AM
crabman173
crabman173
Gapless rings were invented to go in dirt track engines so after 3 races they would still have some compression and put off the re-build by a couple weeks--They make a leak down test look Perfect! That part of the advertisement is 100% true--On the dyno they will not make 1 mor HP in the engines I have done--I used to do the circle track 345-360 HP two barrel limited engines Gapless rings were tested again and again--they NEVER made one more HP They leak checked like amazing though
Have true round no taper cylinder bores by using a TQ plate and many other details --use the cheapest rings on the planet and you will have good ring seal use good rings and it can be less resistance and more HP
I do use gapless second rings in my alky / nitro dragster engine because they do keep oil contamination on that fuel eater ( runs gallons through in seconds) to a minimum but they DO NOT make more power or are any better than conventional ring packs on a drag engine for any other reason
This is from observation not reading about it
[Re: Hemi ragtop]
#2517833
07/05/18 09:01 AM
07/05/18 09:01 AM
Posts: 1,051 The Great White North
RAMM
Gapless--lol. Complete scam. Have used them a few times-all had oil consumption issues. Never use them or recommend them again. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: Hemi ragtop]
#2517983
07/05/18 02:57 PM
07/05/18 02:57 PM
BradH
Well, I used C&A "gapless" 2nd rings two builds ago (similar to the original Total Seal "gapless 2nd), and Total Seal "gapless" top rings w/ traditional 2nd ring and standard-tension oil rings on the build after that. I can't quantify any benefits from either approach, to be blunt.
With my latest (re)build, I returned to conventional top rings and Napier 2nd rings gapped at .020" & .024" respectively. I also went with slightly lighter-tension oil rings (18# vs 21#), but will be keeping an eye on potential oil consumption issues.
"In theory", I like the "gapless" top ring... but you really pay a premium for them. I'd have to see more independent testing from sources I can put 100% faith in before I'd consider trying them again. Since I haven't, my backup short-block parts collection already includes the same ring pack as what I just put into my latest build.
[Re: weedburner]
#2518157
07/05/18 09:14 PM
07/05/18 09:14 PM
madscientist
Washington
I use gapless rings to my advantage. Because they leak so little, they allow me to use a sealed pcv system to draw a vacuum in the crankcase, which in-turn allows me to get away with 12lb oil rings to pick up a little power/mileage. My setup draws 15"Hg crankcase down the hiway, without help from a vacuum pump. I do have an electric pump for backup when I spray, but it's not needed even for the occasional WOT NA blast on a backroad. Don't you know...gapless top rings don't deal. They are all oil burners. That means they are junk. Now that we dispensed with that, I've use probably a hundred sets of gapless top rings. In everything from street cars, to street/strip junk, bracket engines and some heads up stuff. Not one of them has ever had a oil using issue. Not one. The shop I was at when we tested them still uses them. Every day. He still has had an oil user come back.
[Re: madscientist]
#2518197
07/05/18 10:43 PM
07/05/18 10:43 PM
Posts: 4,680 Wichita
GY3
Wichita
I use the Mahle pistons with 1.5, 1.5, 3.0mm file-fit rings and my engine never burns a drop of oil between changes.
I've blown it apart twice since the initial build: once for a bad cam and another for a bearing issue (my fault). Honed it, slammed it back together and zero issues. Set top and 2nd ring gap initially at .024.
[Re: BradH]
#2518295
07/06/18 08:12 AM
07/06/18 08:12 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
"In theory", I like the "gapless" top ring... but you really pay a premium for them. I'd have to see more independent testing from sources I can put 100% faith in before I'd consider trying them again. Since I haven't, my backup short-block parts collection already includes the same ring pack as what I just put into my latest build. So how do you like the Napier 2d ring? I read that they are good for oil control.
[Re: BradH]
#2518296
07/06/18 08:17 AM
07/06/18 08:17 AM
Hemi ragtop
Tennessee
What cylinder finish has been successful with the TS "gapless" top rings? I am interested in that also. There IS some recommendations on the TS website. It makes sense because it changes with different hardness of different block/liner.
[Re: GY3]
#2518299
07/06/18 08:51 AM
07/06/18 08:51 AM
RAMM
I've blown it apart twice since the initial build: once for a bad cam and another for a bearing issue (my fault). Honed it, slammed it back together and zero issues. Set top and 2nd ring gap initially at .024. ^^^^^^The rings that come in their PowerPak piston sets are excellent. They have now gone with a 1.0/1.0/2.0mm ring pack across their lineup and those work excellent as well. J.Rob
[Re: BradH]
#2518303
07/06/18 08:55 AM
07/06/18 08:55 AM
RAMM
What cylinder finish has been successful with the TS "gapless" top rings? If a cylinder finish exists , I haven't found it. I have spent some time on the phone with Keith Jones and have followed his recommendations to a tee even down to the break in oils to stay away from, since he wouldn't outright say which oil to use. J.Rob
[Re: madscientist]
#2518305
07/06/18 09:02 AM
07/06/18 09:02 AM
RAMM
I would think if the benefits such as increased mileage/power/emissions even in a minute amount existed with just a gapless ring design, you would find them in every OEM application around the globe. J.Rob
