Re: 440 build and to what RPM do you reliably turn yours ? [Re: CH3NO2] #251397
03/12/09 05:43 PM
03/12/09 05:43 PM
Nebraska
Lime446 Offline
Lime446  Offline
Nebraska
I've seen them fail at 5500rpm and at 7000rpm. For the price of rod bolts and resizing among the other stuff you need to do to them to make them have a chance at being reliable but limited to probably 6500rpm max a new set of H-beams,etc. are pretty cheap.
Re: 440 build and to what RPM do you reliably turn yours ? [Re: n_bogie1984] #251398
03/12/09 06:05 PM
03/12/09 06:05 PM
Canada
RobR Offline
RobR  Offline
Canada
ok
i myself am running a 440 in my truck and turn it 7500-8000 every time down the track. with a mp .484 hyd cam.
Really...sounds like your tack might be a tad off...
Re: 440 build and to what RPM do you reliably turn you [Re: RobR] #251399
03/12/09 06:13 PM
03/12/09 06:13 PM
Alexandria, VA
SealockRacing Offline
Alexandria, VA
my dad said he used turn his to 7 on the reg
but he went through a few motors
Re: 440 build and to what RPM do you reliably turn yours ? [Re: RobR] #251400
03/12/09 06:33 PM
03/12/09 06:33 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
ok
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=50388356
first run in this video it turned 7800 rpm whole track and peeked to 8300 at the other end of track when carb stuck. second run was in a pull off with heavyer weight and it turned 7600 whole track. yes i perfectly understand diablos point and i know and have talked with him a bunch the problem is i am running a final gear ratio of 9.16 to 1 right now. mine being a standard also and his is a automatic. plus we both have 2 diffrent types of sleds we pull. his is more of a show sled with the weight dropping on you 3/4 down the track, where as ours is a transfer sled.
and this is my fathers cast crank, ly rodded 440 turning 8500 rpm
http://www.youtube.com/watch?v=Yveo-_lnvW8
Re: 440 build and to what RPM do you reliably turn yours ? [Re: n_bogie1984] #251401
03/12/09 06:59 PM
03/12/09 06:59 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
a purple shaft .484 hyd. turning 8000?
Re: 440 build and to what RPM do you reliably turn yours ? [Re: tjmarcus1] #251402
03/12/09 07:06 PM
03/12/09 07:06 PM
Nebraska
Lime446 Offline
Lime446  Offline
Nebraska
5500rpm cam in a 440 no matter how you slice it
Hydraulic lifter can only take so much valve spring and without valve springs
Re: 440 build and to what RPM do you reliably turn yours ? [Re: Lime446] #251403
03/12/09 07:15 PM
03/12/09 07:15 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
ah know all about it, cam about every 10 pulls. need to switch to roller some day. but when your on a .490 lift cam at the valve rule not much for options out there without grinding one. i can also not run any form of quick change gears as doug can, and we pull at each show one time a year so we have no clue what the track is like. 1 week may be sand next may be clay. but you may not beleave but that cast crank 440 has turned 9800 rpms and stayed together. we just rebuild our motors every year and have lady luck on our side most often.
Re: 440 build and to what RPM do you reliably turn yours ? [Re: n_bogie1984] #251404
03/12/09 11:32 PM
03/12/09 11:32 PM
Nevada
dezduster Offline OP
Nevada
I thank everyone for their input.
I am trying to digest all this information. I will likely PM for more detailed info. I must clarify a few things though.
4 Speed NP435 3.34 second gear.Center force dual friction clutch.
Tcase is NP205 1.98 low range.
Gears are
4.56s trac locked dana 60 front 1330 u joints.
Hate to say this but its a corporate GM rear detroit locked 14 bolt 1350 series u joints.
I am stuck with these parts they have proven to be reliable for me.
So my alternate gearing must come from tire sizes unfortunately. But I have a quite a few choices, FRIENDS are great.
I have 5 440s one 400 but my intake and headers are for RB. I know the rods are the weak link at this desired power level and RPM.
Any opinions on what cams would produce both the torque and RPMs requirements?
The compression will likely be 9.8 to 10.2 its currently 10.8 with eddie heads. I have not done the math just know what it was from when we built it for my brother. Im getting his leftovers about time ju ju smiles on me.
Re: 440 build and to what RPM do you reliably turn yours ? [Re: dezduster] #251405
03/13/09 10:28 AM
03/13/09 10:28 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Maybe jus tthe good old reliable mopar .509 if you want ot stay hydrolic. If $$ doesnt matter there are some nice rollar hydrolics out there now
Re: 440 build and to what RPM do you reliably turn yours ? [Re: Diablo] #251406
03/13/09 10:33 AM
03/13/09 10:33 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What rules does the cam have to fit into?
Re: 440 build and to what RPM do you reliably turn yours ? [Re: dezduster] #251407
03/13/09 12:25 PM
03/13/09 12:25 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
AND TO THE POINT. Im building a 440 that needs to rev productively to 6500 and yet make 350+ pound foot of torque as close to 2500 rpm as possible.
The rods are stock LYs with arp bolts,pistons are aries. Heads will likely be stock mopars ported with templates from mopar. Intake is Weiand dual plane,750 Q jet, headers mopar electonic ignition, high 9 compression.
The truck is a 4 speed ,4.56 geared,37 inch everyday tires, 33 inch for pulling, short bed 4x4 dodge.
Ok I punched in the numbers and threw in a solid grind cam with my own specs of 280 @ .050, .600" lift, 106 LSA.
Keep in mind this is using the parts that you specified, 9.8:1 compression, ported 452, and 1.875" headers that are 38" long.
TQ @ 2500 397
HP @ 6500 484
Peak HP 537 @ 5500
Peak TQ 581 @ 4250
HP @ 6500 458
Re: 440 build and to what RPM do you reliably turn yours ? [Re: moparmanjames] #251408
03/13/09 12:34 PM
03/13/09 12:34 PM
Las Vegas NV
Las Vegas NV
Keep in mind that you could gain a ton of bottom end and midrange torque if you sacrificed some hp @ 6500.
Re: 440 build and to what RPM do you reliably turn yours ? [Re: moparmanjames] #251409
03/15/09 12:28 AM
03/15/09 12:28 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I shift my mild 906 headed 440 at 6200 and trap about 6300 to 6400. It seems to like that rpm but I do agree most 440's dont need to go over 6500 unles you have great heads with alot of cam and some good rods. Ron
Re: 440 build and to what RPM do you reliably turn yours ? [Re: moparmanjames] #251410
03/15/09 12:54 AM
03/15/09 12:54 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
TQ @ 2500 397
HP @ 6500 484
Peak HP 537 @ 5500
Peak TQ 581 @ 4250
HP @ 6500 458
280* @ .050 with 9.8:1 compression
I would think that's outcamming your compression by A LOT! I don't think you're going to come up with very good low end torque #'s with that combo. ??
Re: 440 build and to what RPM do you reliably turn yours ? [Re: dezduster] #251411
03/15/09 01:05 AM
03/15/09 01:05 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I'm not sure all tachs are incredibly accurate.
My 484 hydraulic cammed 440 Demon would pull 6400 rpm all the time. After a few years it seemed to me like the tach went higher, so I would hit the recall... 7100 rpm. That's with no changes, nothing. Then it would pull to 6400 rpm for a few months, until it would read 7100 rpm again. It was an Autometer tach too, not an Autogage.
Left me baffled.
CrAzYMoPaRGuY
Re: 440 build and to what RPM do you reliably turn yours ? [Re: RobR] #251412
03/15/09 01:10 AM
03/15/09 01:10 AM
Canada
Canada
ok
LOL
My buddy had my old 1963 Dodge with a hydraulic 484 440, he said he pulled "8000 rpm, easy!"
I laughed.
I took his car for a rip, sure enough, his tach would wind right off the end, past 8000.
I told him it was either out, or set on 6 cylinders. He wouldn't believe me!
CrAzYMoPaRGuY
