Page 5 of 10 1 2 3 4 5 6 7 9 10
Re: Super Sniper install [Re: AndyF] #2513426
06/26/18 12:18 PM
06/26/18 12:18 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
SNIPER Hyperspark distributors do not generate a cam signal because TBI doesn't need it. So you still need the dual-sync distributors for the HP and Dominator.
Re: Super Sniper install [Re: AndyF] #2513459
06/26/18 01:12 PM
06/26/18 01:12 PM
AndyF Offline OP
AndyF  Offline OP
Yes, you would need a dual sync distributor for sequential. Batch fire might work with the Sniper distributor but I don't think I need to try that combination.
I just ordered the Sniper distributor so I should have it in a few days. I think it is smaller than the dual sync so it should fit and work with most valve covers. I'll post pictures when it shows up.
Re: Super Sniper install [Re: AndyF] #2513471
06/26/18 01:30 PM
06/26/18 01:30 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Stupid question, do you still need the cd box with the sniper efi?
Re: Super Sniper install [Re: AndyF] #2513479
06/26/18 01:39 PM
06/26/18 01:39 PM
AndyF Offline OP
AndyF  Offline OP
You can run it old school with a points distributor and a coil if you want but I think most people would want to use a CD box.
I have an old Crane CD box in my car but I'm switching to the new Holley Hyperspark CD box.
Re: Super Sniper install [Re: Mopar_Rich] #2513480
06/26/18 01:43 PM
06/26/18 01:43 PM
central il.
second 70 Offline
second 70  Offline
central il.
Originally Posted By Mopar_Rich
NO TBI EFI system will like a dual plane manifold. Dual planes were designed to generate a "signal" for a carb. TBI EFI wants to inject into an open plenum. If you must use a dual plane manifold then cut the divider out and add at least a 1" open spacer.
Rich I have been waiting for the dual sniper system to be available to install on my 426 hemi. It has a Stage V manifold. Is the equalization port enough of an opening to balance the throttle plates?
I'm lucky enough to know and live within an hour of Matt Bell of redline motor sports to help set the tune.
Thanks Mike
Re: Super Sniper install [Re: second 70] #2513548
06/26/18 04:44 PM
06/26/18 04:44 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The Sniper will work fine with the Stage-V manifold.
Re: Super Sniper install [Re: AndyF] #2513564
06/26/18 05:13 PM
06/26/18 05:13 PM
AndyF Offline OP
AndyF  Offline OP
A dual Sniper would be a trick to do since the ECU is in the throttle body and the cables are hard wired. I have no idea if Holley is going to ship a dual Sniper or not. I think you can do dual Terminators with some home brew engineering. Dual throttle bodies with port injection should be easy but expensive. The Stage V can be ordered with port injection or it might be better to use the Edelbrock EFI intake.
Re: Super Sniper install [Re: AndyF] #2513642
06/26/18 08:39 PM
06/26/18 08:39 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I wasn't sure if when they say, these set ups can also control
Ignition, if that eliminated the need to run an Ignition box
Re: Super Sniper install [Re: JAMESDART] #2513673
06/26/18 10:17 PM
06/26/18 10:17 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
No. It allows control of ignition timing but a CD box and coil are still required.
Re: Super Sniper install [Re: AndyF] #2513803
06/27/18 10:06 AM
06/27/18 10:06 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Did Holley make a new dual sync distributor that fits better than the previous dual sync for BBM? I'm thinking I could clean up the wiring even further with this Holley ignition Hyper Spark setup juxtaposed to my MSD CD box and coil.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Super Sniper install [Re: AndyF] #2518527
07/06/18 06:58 PM
07/06/18 06:58 PM
AndyF Offline OP
AndyF  Offline OP
The new Hyperspark distributor from Holley is smaller than the dual sync so it fits better. It fits the Trick Flow heads without grinding and it fits cast iron heads if the casting flash is removed. It rubs on Edelbrock RPM heads so some minor grinding is required if you have RPM heads.
Re: Super Sniper install [Re: AndyF] #2518528
07/06/18 07:04 PM
07/06/18 07:04 PM
AndyF Offline OP
AndyF  Offline OP
I ran the Super Sniper on my 470 with the Trick Flow 270 heads. That engine made 730 hp with my Dominator and then 710 with the Sniper. I had to use a 4500 to 4150 adapter which kills some power. The Sniper is a tad small for this engine which also kills some power but 710 isn't bad for a low cost throttle body system.
The Super Sniper is rated at 650 hp but there is some margin in that number. My engine was using 85% duty cycle on the injectors at 7000 rpm so there was still a bit left. The airflow was about maxed out though based on the pressure drop across the throttle. The Sniper has a nice data logger so after a dyno run you can just play it all back and look at the manifold pressure, fuel pressure, fuel flow, air fuel ratio, etc. and see what the engine was doing.
Re: Super Sniper install [Re: AndyF] #2518546
07/06/18 07:39 PM
07/06/18 07:39 PM
AndyF Offline OP
AndyF  Offline OP
Here is a picture of the Sniper on the dyno. I'll get a video posted up later on tonight and maybe a screen shot of the data log.
Re: Super Sniper install [Re: AndyF] #2518575
07/06/18 09:12 PM
07/06/18 09:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thanks for the info.I know it's your money spent but, do you think the dominator Sniper would make more on this engine ?
Re: Super Sniper install [Re: CSK] #2518579
07/06/18 09:24 PM
07/06/18 09:24 PM
AndyF Offline OP
AndyF  Offline OP
The Sniper 4500 is for engines making over 800 hp. One of those would work on this engine on the dyno but it might not drive very nice. It might not even idle since it has twice the injector area that this engine needs.
The perfect throttle body for this engine would be a Sniper 4500 with eight 60 lb injectors. That would give me the larger throttle body but the injectors would be the correct size for the engine. At the moment Holley doesn't offer a "build it yourself" Sniper setup. Maybe they will in the future.
Re: Super Sniper install [Re: AndyF] #2518581
07/06/18 09:31 PM
07/06/18 09:31 PM
AndyF Offline OP
AndyF  Offline OP
Here is the Hyperspark ignition kit with the new Mopar distributor. Nice looking distributor, has the new black cap from MSD. The ignition box is a nice shape, has a little bit of curve to it rather than the boxy MSD design.
Re: Super Sniper install [Re: AndyF] #2518599
07/06/18 10:27 PM
07/06/18 10:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Ask Rich about it, if it was port injection those large injectors would be a problem, I dont think it would be a problem on a TBI, Fast & Fitech have them & they work on lower HP engines.
Re: Super Sniper install [Re: AndyF] #2518618
07/06/18 10:58 PM
07/06/18 10:58 PM
AndyF Offline OP
AndyF  Offline OP
In theory a throttle body setup could shut off some of the injectors to avoid the low duty cycle issue but I don't think Holley has that feature in the Sniper line. The Sniper 4500 throttle body is advertised as "not for engines making less than 800 hp". So if they could shut off the injectors at low speed they wouldn't need to advertise it that way.
I do agree, if the software was smart enough to disable half of the injectors at idle then the Sniper 4500 would work on this engine and would most likely make more power.
Re: Super Sniper install [Re: AndyF] #2518631
07/06/18 11:51 PM
07/06/18 11:51 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Originally Posted By AndyF
I don't have any scientific way to measure that. I think you would need 8 O2 sensors to verify distribution issues and I'm not setup with that kind of test gear.
8 EGT's would also work and are a lot easier to install....Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Super Sniper install [Re: AndyF] #2518969
07/07/18 08:29 PM
07/07/18 08:29 PM
AndyF Offline OP
AndyF  Offline OP
Here is a link to the start up video: https://youtu.be/cGljNs28Yp8
