Silver Sport's T56 perfect fit kit shifter relocation
#2511202
06/21/18 03:27 AM
06/21/18 03:27 AM
Posts: 138 Los Angeles, CA
71_dramaqueen
Los Angeles, CA
Looking for any user opinions on Silver Sport Transmission's T56 magnum perfect fit kit for an E body that relocates the shifter to the factory location. Wondering if folks are happy with the shift quality ect and if it's worth the cost over the stock T56M for a non stock car.
Any other user comments on the kit are welcome as well.
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: Silver Sport's T56 perfect fit kit shifter relocation
[Re: 71birdJ68]
#2513710
06/26/18 11:20 PM
06/26/18 11:20 PM
Posts: 18,157 Mass
DAYCLONA
Mass
So, how can it be a perfect fit? Reread Goody's post, he has a "standard" T56, depending on the "factory" T56 used there's about 3-4 "stock" shifter locations used by Mopar/GM/Ford... the SST "relocation modification" is a modification of the tail shaft and shift rails to relocate the shifter to an offset/rearward application for the 70-74 E and 71-2 B body applications, much like what has been done for years with the Tremec TKO 5 spds for the E/B bodies so that the shifter comes up in the stock location so you can use a factory console if so desired... here's a pic of the E body Silver Sport Transmission's relocated shifter on the T56 6 spd bottom pic is Goody's T56 for comparison... Mike
[Re: DAYCLONA]
#2513779
06/27/18 03:49 AM
06/27/18 03:49 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
So, how can it be a perfect fit? Reread Goody's post, he has a "standard" T56, depending on the "factory" T56 used there's about 3-4 "stock" shifter locations used by Mopar/GM/Ford... the SST "relocation modification" is a modification of the tail shaft and shift rails to relocate the shifter to an offset/rearward application for the 70-74 E and 71-2 B body applications, much like what has been done for years with the Tremec TKO 5 spds for the E/B bodies so that the shifter comes up in the stock location so you can use a factory console if so desired... here's a pic of the E body Silver Sport Transmission's relocated shifter on the T56 6 spd bottom pic is Goody's T56 for comparison... Mike That's correct. Mine is centered, technically. I've offset the shifter handle about 1/2" over and 1" back, or so, to help get it closer. That seems to work much better, but if I had the option when assembling, the SST position is where my money would go.
