Silver Sport's T56 perfect fit kit shifter relocation #2511202
06/21/18 03:27 AM
06/21/18 03:27 AM
Los Angeles, CA
71_dramaqueen Offline OP
Los Angeles, CA
Looking for any user opinions on Silver Sport Transmission's T56 magnum perfect fit kit for an E body that relocates the shifter to the factory location. Wondering if folks are happy with the shift quality ect and if it's worth the cost over the stock T56M for a non stock car.
Any other user comments on the kit are welcome as well.
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: Silver Sport's T56 perfect fit kit shifter relocation [Re: 71_dramaqueen] #2513305
06/26/18 12:40 AM
06/26/18 12:40 AM
Los Angeles, CA
Los Angeles, CA
bump
Re: Silver Sport's T56 perfect fit kit shifter relocation [Re: 71_dramaqueen] #2513375
06/26/18 09:24 AM
06/26/18 09:24 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have a standard t56 in my ebody and would love a more factory position, for what that's worth...
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Silver Sport's T56 perfect fit kit shifter relocation [Re: 71_dramaqueen] #2513380
06/26/18 09:44 AM
06/26/18 09:44 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
So, how can it be a perfect fit?
Re: Silver Sport's T56 perfect fit kit shifter relocation [Re: 71birdJ68] #2513710
06/26/18 11:20 PM
06/26/18 11:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Reread Goody's post, he has a "standard" T56, depending on the "factory" T56 used there's about 3-4 "stock" shifter locations used by Mopar/GM/Ford... the SST "relocation modification" is a modification of the tail shaft and shift rails to relocate the shifter to an offset/rearward application for the 70-74 E and 71-2 B body applications, much like what has been done for years with the Tremec TKO 5 spds for the E/B bodies so that the shifter comes up in the stock location so you can use a factory console if so desired...
here's a pic of the E body Silver Sport Transmission's relocated shifter on the T56 6 spd
bottom pic is Goody's T56 for comparison...
Mike
Re: Silver Sport's T56 perfect fit kit shifter relocation [Re: DAYCLONA] #2513779
06/27/18 03:49 AM
06/27/18 03:49 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Mike
That's correct. Mine is centered, technically. I've offset the shifter handle about 1/2" over and 1" back, or so, to help get it closer. That seems to work much better, but if I had the option when assembling, the SST position is where my money would go.
2020 RAM 1500
