MOLY Driveshaft #251240
03/11/09 10:59 PM
03/11/09 10:59 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
I just got a .083 D.O.M. MOLY driveshaft that will need cut and shortened.
I have heard that it is OK to MIG MOLY........
I have also been told to TIG ONLY!!!!
Who has done this?
Whats the pro`s and con`s?????????
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Post deleted by Defbob [Re: 6bblFLASH] #251241
03/11/09 11:02 PM
03/11/09 11:02 PM
Re: MOLY Driveshaft #251242
03/11/09 11:04 PM
03/11/09 11:04 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
On a high stress part, why take the chance? If it were me, I'd have it TIG welded.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: MOLY Driveshaft [Re: dusturbd340W5] #251243
03/12/09 08:52 AM
03/12/09 08:52 AM
N.E. Ohio
N.E. Ohio
The ends are already MIG`d on, so how do you tell if it really IS MOLY?
Re: MOLY Driveshaft [Re: 6bblFLASH] #251244
03/12/09 09:08 AM
03/12/09 09:08 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have seen a few moly shafts and they were mig welded from the builder.
Re: MOLY Driveshaft [Re: 6bblFLASH] #251245
03/12/09 09:58 AM
03/12/09 09:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
To look at it you couldnt tell the difference.... thats
one thing that you have to take the manufacturer word on
material wise but you can tell DOM... it wont have a seam
Re: MOLY Driveshaft [Re: MR_P_BODY] #251246
03/12/09 06:45 PM
03/12/09 06:45 PM
N.E. Ohio
N.E. Ohio
Ok I`ll look,and see if I can see anything........
Post deleted by Defbob [Re: 6bblFLASH] #251247
03/12/09 06:50 PM
03/12/09 06:50 PM
Re: MOLY Driveshaft #251248
03/12/09 11:14 PM
03/12/09 11:14 PM
N.E. Ohio
N.E. Ohio
Who built the shaft?
I have no idea,bought it with a trans. out of Wisconsin.
I did clean off the paint ,NO seam. So it is D.O.M.
Its a 3-1/2 dia. 1350 series joints.
