my fresh BB won't idle #2511868
06/22/18 07:05 PM
06/22/18 07:05 PM
nj
JAMESDART Offline OP
nj
I'm looking for some ideas with my 451, trick flow240 heads, 11:1, m1 intake, comp solid flat tappet XTQ294S-8, quickfuel 1050an carb. I bought the carb off a member here don't remember his name. Was supposed to be used very little. I tried a 750 I have and it wasn't much different. I do have another carb I could try.
Right now with the 1050 it's idling at 1650. If I lower either idle speed screw 1/4 turn it dies. With 4 corner mixture screws I have to have them only like 1/2 turn out. Timing is around 25. It don't want to start, or restart. I have to give it a lot of gas and open the throttle to get it to fire and stay running.
Vac is 11"
I want to go through the valves, but I haven't yet.
Re: my fresh BB won't idle [Re: JAMESDART] #2511879
06/22/18 07:28 PM
06/22/18 07:28 PM
I would look for vacuum leak to start with, you've already tested two different carbs that had the same problem on your motor work scope
is the PCV port,tube, on the carb blocked off? scope
Re: my fresh BB won't idle [Re: JAMESDART] #2511881
06/22/18 07:35 PM
06/22/18 07:35 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i would go 1.5 turns out on the idle MIX screws, try to get it running and the idle close enough that you can lean our the idle mix after the motor is warm.
yes, def check that the PCV hose is hooked up to the carb.
are both accelerator pumps working?
Re: my fresh BB won't idle [Re: Cab_Burge] #2511890
06/22/18 08:31 PM
06/22/18 08:31 PM
I would look for vacuum leak to start with.
X2
Re: my fresh BB won't idle [Re: JAMESDART] #2511896
06/22/18 08:52 PM
06/22/18 08:52 PM
AndyF Online content
AndyF  Online Content
Sounds like a vacuum leak so look for that before you tune the carb.
If there isn't a vacuum leak then you'll need to sort out the idle circuit since it is way off. If you don't have a wide band then you'll have to do it the old way. Get it running at a fast idle and then start to turn the idle mixture screws. If it dies when you screw them out then you are too rich. If you are too rich at 1/2 turn out then the IFR in the metering blocks are too big. Reduce the size by a couple of numbers and try again.
A 1050AN is a very tunable carb. Do you have the right jets for that carb. The idle jets are a small size. Getting the idle circuit correct is the key to having the carb run right.
Re: my fresh BB won't idle [Re: JAMESDART] #2511906
06/22/18 09:19 PM
06/22/18 09:19 PM
nj
nj
I did go through the old school way with the mixture screws. It runs smoothest and highest vac with them 1/2 turn out. The 750 liked them farther out, like 1-1/2. I figured the 1050 idle circuit needed some work after that. I pulled the intake off looking for any sign of a vac leak. I have the bathtub with gasket on each side. The gaskets had a good imprint from the bathtub, BUT on the bottom rear ports the gaskets were wet. I couldn't tell if it was from gas or it was sucking oil up from the valley pan. I don't like the imprint on the carb gasket vs the spread ore pattern on the m1. I did spray carb cleaner around the carb base, and the top of the intake to head, but maybe it's leaking on the bottom side?
Re: my fresh BB won't idle [Re: JAMESDART] #2512000
06/23/18 12:33 AM
06/23/18 12:33 AM
IL
furious70 Offline
furious70  Offline
IL
You should be able to squirt some in the valley. As bad as it sounds like it is if it's leaking under there it'll probably flutter
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: my fresh BB won't idle [Re: JAMESDART] #2512025
06/23/18 01:56 AM
06/23/18 01:56 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If you take air away from the top of the carb and the engine gets happy, it's sucking air from somewhere else.
Re: my fresh BB won't idle [Re: JAMESDART] #2512064
06/23/18 09:17 AM
06/23/18 09:17 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
I had an m1 leaking thru the stud. I epoxied it in and it worked out.
Do a squirt test see if that works.my .02$
Re: my fresh BB won't idle [Re: JAMESDART] #2512081
06/23/18 10:43 AM
06/23/18 10:43 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not sure on that carb, but on my Holley HP, the hole for the air filter stud goes through the carb and will have a vacuum leak if no stud (or bolt) is installed.
Being a used carb, check the sizes of the air bleeds, idle restrictions, power valve restriction, jets, and emulsion holes and see if they have been changed from the stock specs.
Re: my fresh BB won't idle [Re: JAMESDART] #2512134
06/23/18 12:42 PM
06/23/18 12:42 PM
nj
nj
Air bleeds are stock, jet is a couple sizes smaller than stock, I didn't check the restrictions.
Re: my fresh BB won't idle [Re: JAMESDART] #2512176
06/23/18 02:13 PM
06/23/18 02:13 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Where do you have the initial and total timing set at?
Do you have vacuum leaks?
Are you running a PCV valve?
Re: my fresh BB won't idle [Re: JAMESDART] #2512207
06/23/18 03:16 PM
06/23/18 03:16 PM
nj
nj
Initial is around 25. I'm not sure where the total is at. Don't know if I recurved this distributor already or not.
Re: my fresh BB won't idle [Re: JAMESDART] #2512247
06/23/18 05:23 PM
06/23/18 05:23 PM
Open up the carb and post what all of the jet sizes are. Mains, idle, emulsion, air bleeds, etc. Post pictures if you can.
You might have a gasket problem or a vacuum leak or just a carb that is way off. Hard for us to help you though if you don't give us the details.
Re: my fresh BB won't idle [Re: JAMESDART] #2512256
06/23/18 05:54 PM
06/23/18 05:54 PM
nj
nj
Are the feed restrictions marked? I can do that.
I don't think this carb has the air bleed air cleaner stud deal.
I have pcv valve in the valve cover and a breather in the other.
I went and picked up
Some carb cleaner and used it to try to find vac leak. Put air cleaner on and did some spraying
I get a change in 2 areas, seemed like between carb body and baseplate, and under the intake.
Re: my fresh BB won't idle [Re: JAMESDART] #2512405
06/24/18 12:22 AM
06/24/18 12:22 AM
Your on the correct path, fix those area next and then think hard about fixing the oil seeping into the intake manifold from the valley pan up twocents
Re: my fresh BB won't idle [Re: JAMESDART] #2513666
06/26/18 09:56 PM
06/26/18 09:56 PM
nj
nj
I removed the intake and the paper gaskets. There was signs of oil getting between the gaskets and valley pan. i want to try just the tin, is it a bad idea with aluminum intake and head? I sat the intake on with no gasket or tin and it is nice and tight. I never used the paper gaskets. I had a rpm and stealths on the last one with just the tin, but didn't run that setup very long.
Re: my fresh BB won't idle [Re: JAMESDART] #2513745
06/27/18 12:54 AM
06/27/18 12:54 AM
Remove the valley pan and clean both the heads and intake mating surfaces very thoroughly and then take a set of feeler gauges with a .0010 to .0025 gauge and set the intake on the heads and rock it around to locate it and then see if you can get your thinnest feeler gauge to go between the heads and intake surfaces at the bottom and top of each manifold corner scope Write down what you find on each corner, top and bottom wrench
Let us know what you find scope wrench up
Re: my fresh BB won't idle [Re: JAMESDART] #2513782
06/27/18 04:23 AM
06/27/18 04:23 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Is it fixd yet
Re: my fresh BB won't idle [Re: JAMESDART] #2513790
06/27/18 08:09 AM
06/27/18 08:09 AM
nj
nj
Yeah I tried that, With the intake sitting on dry and can't get my thinnest feeler gauge in anywhere around the intake.
