Re: my fresh BB won't idle
[Re: JAMESDART]
#2511879
06/22/18 07:28 PM
06/22/18 07:28 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
I would look for vacuum leak to start with, you've already tested two different carbs that had the same problem on your motor is the PCV port,tube, on the carb blocked off?
[Re: Cab_Burge]
#2511890
06/22/18 08:31 PM
06/22/18 08:31 PM
RapidRobert
I would look for vacuum leak to start with. X2
[Re: JAMESDART]
#2512000
06/23/18 12:33 AM
06/23/18 12:33 AM
Posts: 2,255 IL
furious70
IL
You should be able to squirt some in the valley. As bad as it sounds like it is if it's leaking under there it'll probably flutter
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: JAMESDART]
#2512081
06/23/18 10:43 AM
06/23/18 10:43 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Not sure on that carb, but on my Holley HP, the hole for the air filter stud goes through the carb and will have a vacuum leak if no stud (or bolt) is installed.
Being a used carb, check the sizes of the air bleeds, idle restrictions, power valve restriction, jets, and emulsion holes and see if they have been changed from the stock specs.
[Re: JAMESDART]
#2512176
06/23/18 02:13 PM
06/23/18 02:13 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Where do you have the initial and total timing set at?
Do you have vacuum leaks?
Are you running a PCV valve?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: JAMESDART]
#2512405
06/24/18 12:22 AM
06/24/18 12:22 AM
Cab_Burge
I get a change in 2 areas, seemed like between carb body and baseplate, and under the intake.
Your on the correct path, fix those area next and then think hard about fixing the oil seeping into the intake manifold from the valley pan
[Re: JAMESDART]
#2513666
06/26/18 09:56 PM
06/26/18 09:56 PM
Posts: 619 nj
JAMESDART
nj
I removed the intake and the paper gaskets. There was signs of oil getting between the gaskets and valley pan. i want to try just the tin, is it a bad idea with aluminum intake and head? I sat the intake on with no gasket or tin and it is nice and tight. I never used the paper gaskets. I had a rpm and stealths on the last one with just the tin, but didn't run that setup very long.
[Re: JAMESDART]
#2513790
06/27/18 08:09 AM
06/27/18 08:09 AM
Posts: 619 nj
JAMESDART
nj
Yeah I tried that, With the intake sitting on dry and can't get my thinnest feeler gauge in anywhere around the intake.
