Re: Well said, Marq!
[Re: Marq]
#25118
07/17/06 02:39 PM
07/17/06 02:39 PM
the only thing stopping me fron using a rattle can, is the fact that my gallon color (safety yellow) and the spray bomb color (sunshine yellow) didnt have the same name. I think i'll get a can, and see if it matches.
Oh, and i'm a avid rattle can sprayer, only way i've painted for 3 yeras. (see attached pic) Tha's my show car, rattle can painted in my garage, black primer.
#25119
07/17/06 02:41 PM
07/17/06 02:41 PM
Re: Paint job on a budget!? CONTINUED..page 44........
#25122
07/17/06 04:07 PM
07/17/06 04:07 PM
Cal96:
I'm also using the Wagner (Which is now $45 after rebate @ Home Depot, btw) and I have a couple of questions:
I'm finding that I can't spray properly when I hold it perpendicular to flat surfaces: How did you spray horizontal surfaces like the roof and the hood?
How many coats did you use total? I have about 1.7 coats (I put on a roller coat before I sprayed, but I took it down with some 800) and I'm getting pretty good coverage... I'm thinking 4 coats would be enough? I'm hoping to finish this before the weekend.
-Morwan
#25123
07/17/06 05:31 PM
07/17/06 05:31 PM
Cal96:
-Morwan
$45 bucks? did anyone sign the paper or anything...maybe i can just grab a rebate paper and send it in...lol.
perpendicular spray: the gun has a "L" like shape nosal...when you angle the gun, more paint will lean to that side....th "L" can be moved to pointing back, if you are painting upward..cuz all the paint will be moving downward...you should have less problem if the container was full but we arent spraying that much. i think mines was at 40 not sure, ill check again later. but your car might be diff. mines, i just had it pointing forward , away from me. so when im painting down (perpendicular) most of my paint will be at the front of the container...also i spray the hard part first...i had nothing to hold my fenders, bumper to an higher ground where its easier to spray. so i spray those part first...on the roof, i was standing on a chair. spray one side then go around and spray the other. and make sure you hold the cable with your left hand and spray with your right (if right handed). them cables be touching everywhere! and water the ground so dust dont fly up when spraying. that should cover the hood too.. i used about 6-7 i guess, some day would be thicker then others. i had this problem only cause i was mixing still and wanted to see what color i liked (adding black, then thinner then more black...) so my car isnt one same color of layer...only last 3 where same. sanded it all with 800 grit. try to spray it smooth without orange peels as possible. omg, i cannot tell you if you dont youll be wetsanding the whole car everytime you finish your layer...thats pain in the butt. also do NOT use cheap tape when taping up your car. if you dont listen youll find out later. yes, 4 coat could be enough. if you dont have sand marks showing or bondo area. just spray slightly thicker and let it bake in the sun. next day if i dont smell paint i know its dry. good luck!
#25124
07/17/06 06:07 PM
07/17/06 06:07 PM
If you bought the sprayer at home depot, all you need is the UPC and the receipt. Here's a link to the rebate form: FIXED LINK (Thanks Jaco D) http://www.homedepot.com/cmc_upload/HDUS...oorProducts.pdfJust send it in before the end of the month and you should be fine. Thanks for the tips! Second/Third coat will be going on in an hour... Then wetsanding tomorrow. I'd like to put more coats on, but I've got to use the car on Saturday. :/ -Morwan
#25125
07/17/06 08:34 PM
07/17/06 08:34 PM
Posts: 59 St Andrews ,Manitoba ,Canada
C38coupe
I asked this question earlier in the thread, but here goes again. What product do I use to treat rust pits in my metal on my 48 Chrysler Coupe, after it's been sanded and before it's primered/painted. I am bargain hunter so what out there is cheap in price, yet effective, in a perfect world I would have my entire exterior of my car soda blasted, before I got my $5000.00 paint job. This car is made with 18 gauge high quality sheet metal, but after sanding out some panels, I am not able to get out all the pits left behind by surface rust and rust pits..........Fred PS any automotive primer thats compatible with enamels could anyone recommend, or should I just use Tremclad primer
[Re: C38coupe]
#25127
07/17/06 09:04 PM
07/17/06 09:04 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
I do not know what the specific product name is... but there is an interesting chemical that is used by windshield installers... that just might be what you are looking for...
On older cars... when the windshield installer removes the windshield, sometimes there is rust holes found under where the windshield was mounted on the window frame. Half the time there are similar rust throughs on the pillars.
Anyhow, to make a long story short ( as if I could ever do that )... the windshield installers usually grind out the rusted area and then coat the area with a liquid that they apply with a small paint brush. Sometimes the paint brush is build right into the bottle that this stuff comes in.
This 'brown liquid' does two jobs... it KILLS any future rust wherever it is applied AND it builds up a layer that has the appearance of a thick primer. You can sand this 'brown primer' when it dries and it provides a stable surface that you can work further on with additional sanding or priming etc.
If I am correct you could give a call around to a couple of your local windshield installers and ask them what chemical they use to kill rust pits that they find under windshields.
Some of the 'crappy' windshield installers will just put a tar type coating over rust pits... but that doesn't displace water or block oxygen getting through to the rust pits. But then again the crappy installers don't really care because they are going to slap new glass over the area and this defective repair won't be found out until the next time you replace the windshield glass.
There is a similar product in a small bottle ( with a brush built into the cap ) that is sold at Pep Boys ( in the States ) or through auto body and paint jobbers ( the guys that supply shop supplies to the body shops ) and possible even at Canadian Tire ( for the folks in Canada ). The stuff is fairly cheap ( costwise ). Less than $10 a bottle.
If you locate this wonderous rust killing liquid... you just dab it onto any of the rust pits that remain after you rough grind the area.
Since the stuff is fairly thick ( like a thick paint ) it goes on and gives pretty good coverage. You can then lay some bondo over it and they are quite compatible. Bondo sticks amazingly well to this stuff.
I had to use it on my McLaren about three years ago when I first started doing the bodywork on the car. The car then sat outside for two years in Pennsylvania and then in a garage in Ottawa for three years... and all the bodywork that was done on that area HELD TRUE for all that time... no re-occurence of rust and no expansion/contraction of the rust coating against the bondo layer that was placed over it.
I wish I could give you the product name... but hopefully a few quick phone calls to the more reputable windshield replacement companies will lead you in the right direction.
At the time it was a brown glass bottle - with a brush built into the cap.. and the goop inside is also brownish in appearance I believe..
[Re: C38coupe]
#25128
07/17/06 09:53 PM
07/17/06 09:53 PM
Well guys, I finally got started on my cheap paint job. I found this thread a couple of weeks ago and stayed up all night reading the entire thread. Here is a picture of the 4th coat of Regal Red on the hood. I am amazed at how well the paint lays down. It would be better if I didn't have to paint in a dirt floor barn.
#25129
07/17/06 09:56 PM
07/17/06 09:56 PM
Here is what I hope the truck will look like when it is finished. Ignore the lack of skill with photoshop. Colors are regal red, canvas white and almond.
#25130
07/18/06 12:18 AM
07/18/06 12:18 AM
I found this thread on coloradok5.com All i can say is WOW this is very cool. Soon as i close on my house im doing it to my 79 3/4 4x4 Chevy truck! Ive attached a pic also of what the truck looks like as of now. Can i get pretty much any color? I really like the color blue on the new Monte Carlos. Is that possible. If not im going orange. Also is a satin black available for doing the interior?
#25131
07/18/06 01:13 AM
07/18/06 01:13 AM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Very nice tx4wheeler! Good to see another using canvas white .
The canvas white does seem like it would go well with a dark red.
#25132
07/18/06 03:38 AM
07/18/06 03:38 AM
[url=http://www.homedepot.com/cmc_upload/HDUS/EN_US/pc/common/pdfs/042706_072606_WagnerPaintProducts.pdf]
-Morwan
Pardner, here's the right rebate form:
Bought the unit last week to waterproof my folks' deck. Was in the middle of trying this roller method on my daily driver when I thought of using the Wagner on the car. The only thing is it might take a while since I'm completely stripping the car to metal. It's a 92 japanese import, and from what I've heard, finishes on cars of that era weren't that great due to environmental concerns regarding the type of paint that can be applied (don't quote me on this - this is news passed on for the nth time). Anyway, the paint is in bad shape. On top of the car's original paint, sporadic layers of spray bomb paint and a lousy MAACO paint job have been applied so I decided to strip the thing to bare metal and start from there. It took me one and a half weeks of after office time (till the sun went down) just to strip the hood to bare metal using an 18-volt cordless drill and 80-grit 3M sanding pads. Haven't yet decided to strip the car in one shot then do the roller thing or do a "strip/roll/strip/roll,etc." (ok boys, don't let your imaginations run wild ) while doing one panel at a time. Of course, the Wagner is another option.
By the way, to those who bought the Wagner, it has a simple viscosity checker which comes with it to determine whether the paint is thin enought for the HVLP spayer. Anyway, have you tried "rolling" that mixture and what are the results? I'm thinking, if it's thin enough for the sprayer, then it might be thin enough to be rolled with the least amount of problems (orange peel, etc.).
Just trying to come up with a standard or benchmark for an acceptable paint thickness.
Here's what that contraption looks like:
http://www.gleempaint.com/viscosity-cup.html
Refer to page 4 of the Wagner manual on how to use it.
http://lib.store.yahoo.net/lib/gleempaint/control-spray.pdf
#25133
07/18/06 07:02 AM
07/18/06 07:02 AM
Very nice, 4-wheeler! Another truck brought back from the grave.
I swear, it's just about as much fun watching how other folks' projects come out than doing your own...of course ya don't have to clean up after other folks....
The hood looks great! Please keep us up to date. I'm back for my 1000 grit sanding this weekend, then the final exterior coats (weather permitting). Still got a few rough spots to work on.
#25134
07/18/06 03:36 PM
07/18/06 03:36 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
#25135
07/18/06 03:53 PM
07/18/06 03:53 PM
Whoops, I pasted that link at first and I thought I had corrected it.. Didn't bother to check. Original post is fixed now.
Put on the second spray coat, the coverage is excellent (the car is one color now!) It drives me nuts seeing my car covered in white fuzz ten minutes after I lay down the coat, and I think a bird crapped on my car this morning.
If you need to get rid of rust, I'd recommend POR-15. It's pretty expensive (a can of it was $35 at my local body supply store), but it's an all-in one product that works: it converts, seals, and primes rust.. And I've never heard of it failing.
#25136
07/18/06 04:31 PM
07/18/06 04:31 PM
Posts: 369 Lubbock, TX
slantvaliant
Lubbock, TX
I used a rust converter spray to kill the rust. There are several brands, usually somewhere in the paint aisle. Rustoleum even has one. Then, you can use a sandable primer to fill them, or even a skim coat of filler.
