Re: What now for this b1 exhaust port
[Re: kevinlc]
#2511946
06/22/18 11:03 PM
06/22/18 11:03 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
That converts to @28 intake 389.5, Ex @ 28 264.6,, Take it to the track & see what it runs.
[Re: kevinlc]
#2511956
06/22/18 11:17 PM
06/22/18 11:17 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Im no head guru but my maxed out SR's flow 368 @ .750 lift . Yours should be better or capable of being better.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: kevinlc]
#2511976
06/22/18 11:41 PM
06/22/18 11:41 PM
Posts: 4,457 Washington
madscientist
Washington
Don't worry about the exhaust.
Don't kill yourself over flow numbers. If the valve job is correct and the port work wasn't done with a body grinder you'll be fine.
[Re: Twostick]
#2511988
06/23/18 12:07 AM
06/23/18 12:07 AM
madscientist
Washington
Who flows heads at 25"?
Kevin Many do. That's why I said don't get ate up over flow numbers. It's not like Barton is stupid.
[Re: kevinlc]
#2511996
06/23/18 12:26 AM
06/23/18 12:26 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Local mopar racer. Says it’s makes more realistic numbers. Didn’t know this till I picked them up. Anyway, this motor should make more power buts it’s not. The 68 dart only runs 9.90 at 137 mph at 3100 lbs That’s pathetic. Something wrong big time with that combo.
[Re: kevinlc]
#2512079
06/23/18 10:32 AM
06/23/18 10:32 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I doubt a 451 with B1 heads in a 3100lb car needs the heads to be any “bigger”(more porting).
I’m not sure if this is still the case, but SuperFlow used to have their flow benches calibrated at 25”, so some shops used that as the test pressure.
[Re: kevinlc]
#2512097
06/23/18 11:30 AM
06/23/18 11:30 AM
BradH
Had my standard b1’s race ported by Barton many years ago and flowed them a few days ago. The exhaust only flows 250 cfm at 550 lift at 25”. Valve size is 1.785. No gain from 550 to 800 lift. 2.300 intake maxes out at 368 cfm at .700 lift at 25”. This is an all out race motor with a roller cam. Is there more flow to be gained? This 451 race motor only made 794 hp at 7300 and 599 tq at 6300. What should I do? Start by putting a 4.25"-stroke crank in it to make better use of those big ports.
[Re: kevinlc]
#2512284
06/23/18 07:45 PM
06/23/18 07:45 PM
Posts: 9,836 MI, usa
dvw
MI, usa
I think the converter is the issue. I run way more stall speed and less cam in my 572, 6100 flash stall. That is a lot of cam for a small motor. With the right converter that thing should run pretty decent. I'm sure with that cam and heads it would be even better on a 528/540 short block. Doug
[Re: kevinlc]
#2512314
06/23/18 09:19 PM
06/23/18 09:19 PM
fast68plymouth
So. Burlington, Vt.
Yes and dynoed it also Max hp is 794 at 7300 Tq is 599 at 6300 Motor makes peak tq at 6300........ and you have a 5500 converter. That’s the first thing I’d be addressing.
