Page 1 of 3 1 2 3
What now for this b1 exhaust port #2511922
06/22/18 10:06 PM
06/22/18 10:06 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Had my standard b1’s race ported by Barton many years ago and flowed them a few days ago. The exhaust only flows 250 cfm at 550 lift at 25”. Valve size is 1.785. No gain from 550 to 800 lift. 2.300 intake maxes out at 368 cfm at .700 lift at 25”. This is an all out race motor with a roller cam. Is there more flow to be gained? This 451 race motor only made 794 hp at 7300 and 599 tq at 6300. What should I do?
Re: What now for this b1 exhaust port [Re: kevinlc] #2511946
06/22/18 11:03 PM
06/22/18 11:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
That converts to @28 intake 389.5, Ex @ 28 264.6,, Take it to the track & see what it runs.
Re: What now for this b1 exhaust port [Re: kevinlc] #2511956
06/22/18 11:17 PM
06/22/18 11:17 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Im no head guru but my maxed out SR's flow 368 @ .750 lift . Yours should be better or capable of being better.
1963 Plymouth Max Wedge
1971 Barracuda
Re: What now for this b1 exhaust port [Re: kevinlc] #2511976
06/22/18 11:41 PM
06/22/18 11:41 PM
Washington
madscientist Offline
Washington
Don't worry about the exhaust.
Don't kill yourself over flow numbers. If the valve job is correct and the port work wasn't done with a body grinder you'll be fine.
Re: What now for this b1 exhaust port [Re: kevinlc] #2511977
06/22/18 11:41 PM
06/22/18 11:41 PM
Me thinks the machine shop, flow tester, goof up something on your heads testing them tsk
I've had a bunch of different BB Mopar heads flow from bone stock 906 and 1963 M.W. heads up to several different sets of MCH CNC ported 440-1 and one set of B1 ported by Koffels. the CNC ported 440-1 with 2.250 intake valves flow right at 370 CFM at 28 inches at .700 valve lift on the intakes on a Super Flow 600 bench with a 4.375 bore and the B1 heads on the same bench with the same bore size flowed 420 CFM at .700, 430 CFM at .900 and at 1.00 lift shruggy
If I was you and wanted to learn more I would call Bob at MCH (568-468-7914) and talk to him about your heads. I'm sure Ray Barton did a decent job on your heads but I don't know what you wanted them to accomplish originally work shruggy
Re: What now for this b1 exhaust port [Re: kevinlc] #2511980
06/22/18 11:47 PM
06/22/18 11:47 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Who flows heads at 25"?
Kevin
Re: What now for this b1 exhaust port [Re: Twostick] #2511987
06/23/18 12:07 AM
06/23/18 12:07 AM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Local mopar racer. Says it’s makes more realistic numbers. Didn’t know this till I picked them up. Anyway, this motor should make more power buts it’s not. The 68 dart only runs 9.90 at 137 mph at 3100 lbs
Re: What now for this b1 exhaust port [Re: Twostick] #2511988
06/23/18 12:07 AM
06/23/18 12:07 AM
Washington
Washington
Kevin
Many do. That's why I said don't get ate up over flow numbers.
It's not like Barton is stupid.
Re: What now for this b1 exhaust port [Re: kevinlc] #2511996
06/23/18 12:26 AM
06/23/18 12:26 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That’s pathetic. Something wrong big time with that combo.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What now for this b1 exhaust port [Re: pittsburghracer] #2512033
06/23/18 02:26 AM
06/23/18 02:26 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree The combo is off if it really makes 800. What are the short times from your Dart?
Re: What now for this b1 exhaust port [Re: kevinlc] #2512079
06/23/18 10:32 AM
06/23/18 10:32 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I doubt a 451 with B1 heads in a 3100lb car needs the heads to be any “bigger”(more porting).
I’m not sure if this is still the case, but SuperFlow used to have their flow benches calibrated at 25”, so some shops used that as the test pressure.
Re: What now for this b1 exhaust port [Re: kevinlc] #2512097
06/23/18 11:30 AM
06/23/18 11:30 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Start by putting a 4.25"-stroke crank in it to make better use of those big ports.
Re: What now for this b1 exhaust port [Re: kevinlc] #2512120
06/23/18 12:14 PM
06/23/18 12:14 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
I'd like to see more about the combo. What cam and compression, transmission converter and gear?
Re: What now for this b1 exhaust port [Re: B1HEAD_USER] #2512236
06/23/18 04:50 PM
06/23/18 04:50 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
The combination is a 15:1 451 cid with b1 original heads, sheet metal intake with two 1050’s, roller cam with .845 intake 285 duration and .766 exhaust and 299 duration ground on 110 lobe separation. Exhaust is 2 to 2/18 equal length. Trans is a 727 with a brake, 5500 stall, 14x32 and 5:13 gears. With the exhaust limit of .550 lift, I think the two dominators are killing the motor.
Re: What now for this b1 exhaust port [Re: kevinlc] #2512240
06/23/18 05:06 PM
06/23/18 05:06 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
did barton do the whole motor ???
Re: What now for this b1 exhaust port [Re: HEMI472] #2512248
06/23/18 05:30 PM
06/23/18 05:30 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Yes and dynoed it also
Max hp is 794 at 7300
Tq is 599 at 6300
Re: What now for this b1 exhaust port [Re: kevinlc] #2512284
06/23/18 07:45 PM
06/23/18 07:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I think the converter is the issue. I run way more stall speed and less cam in my 572, 6100 flash stall. That is a lot of cam for a small motor. With the right converter that thing should run pretty decent. I'm sure with that cam and heads it would be even better on a 528/540 short block.
Doug
Re: What now for this b1 exhaust port [Re: kevinlc] #2512314
06/23/18 09:19 PM
06/23/18 09:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
Tq is 599 at 6300
Motor makes peak tq at 6300........ and you have a 5500 converter.
That’s the first thing I’d be addressing.
Re: What now for this b1 exhaust port [Re: fast68plymouth] #2512343
06/23/18 10:53 PM
06/23/18 10:53 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Converter probably is 6000. I sent the dyno sheet to the company
Re: What now for this b1 exhaust port [Re: kevinlc] #2512562
06/24/18 01:16 PM
06/24/18 01:16 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
do you have a way to see the flash during a run and what it rpm's at the shifts? I have a play back box on my tach which was great for this. That will show what the converter is doing.
Page 1 of 3 1 2 3
