engine id from bottom of engine up on a lift #2511921
06/22/18 10:02 PM
06/22/18 10:02 PM
Chattanooga, TN
orange elephants Offline OP
Chattanooga, TN
Can anyone tell me if the engine in the picture is a 318 or a big block? It's in a 1961 Dodge.
Re: engine id from bottom of engine up on a lift [Re: orange elephants] #2511924
06/22/18 10:10 PM
06/22/18 10:10 PM
jersey
Spaceman Spiff Offline
jersey
can see any picture. where is the oil filter?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: engine id from bottom of engine up on a lift [Re: orange elephants] #2511929
06/22/18 10:22 PM
06/22/18 10:22 PM
Is the oil pan flat all the way around the bottom of the motor oil pan rails or does it curve around the timing cover and at the rear of the oil pan around the rear main bearing cap?
If flat it is a BB, if it curves around the front and back it is a SB scope
Re: engine id from bottom of engine up on a lift [Re: orange elephants] #2511931
06/22/18 10:22 PM
06/22/18 10:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Where's the distributor? BB is at right front. SB is in the rear.
Re: engine id from bottom of engine up on a lift [Re: topside] #2511932
06/22/18 10:34 PM
06/22/18 10:34 PM
Chattanooga, TN
Chattanooga, TN
Sorry about the lack of a picture. I have been trying to post the picture and I am extremely frustrated that it won't let me do it.
[img]"C:\Users\Owner\Pictures\CARS\1960 dodge conv lr\1961 conv"[/img]
Re: engine id from bottom of engine up on a lift [Re: orange elephants] #2511942
06/22/18 10:58 PM
06/22/18 10:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Is not going to work, that address is on your computer.
Right under the window you typed your initial post in is a link called "File Manager (Total Files: 0)" click on it
a window will pop up,
click on "Browse" and got to C:\Users\Owner\Pictures\CARS\1960 dodge conv lr\1961 conv
Click on it and add file, then click on doine adding files and post
That should do it
Don't be the exception.
Re: engine id from bottom of engine up on a lift [Re: Spaceman Spiff] #2512032
06/23/18 02:22 AM
06/23/18 02:22 AM
CA
crackedback Offline
crackedback  Offline
CA
That's the easiest way.
Pass side is a SB
Dr side is a BB
for A and B/RB mills
